digitizing 23.98 1080p not psf from a d-5 into final cut
cory tardy
on Jun 16, 2010 at 6:09:11 pm
hello,
I am trying to digitize 1080p from a D-5 into final cut. I am running a aja kona 3. There's no 1080p capture preset only 1080psf. When I go into the capture settings and edit them to match what the decks putting out I still have no luck.
Any idea's?
cory
Jeremy Garchow
Re: digitizing 23.98 1080p not psf from a d-5 into final cut
on Jun 16, 2010 at 6:28:20 pm
Quit FCP. GO in to the AJA Control panel's setup tab and click the 1080 Progressive option under "geometries". Open FCP and you should have 1080p now.
Jeremy
cory tardy
on Jun 16, 2010 at 6:43:31 pm
under that tab it says thats for video output, I need video input?
Jeremy Garchow
on Jun 16, 2010 at 7:02:19 pm
If you Quit FCP first, it will load the 1080p easy setups.
Hit control-q to bring up the easy setups.
Also, if that doesn't work for you, then reinstall the drivers, except once you get to the easy setup portion, uncheck the driver and base part and install the 'additional 23.98' setups.
Here's a pic from an ioExpress install, but it works the same for Kona.
Jeremy
