dvcpro hd to sd conversion problem
carlos cidre
on Jun 15, 2010 at 11:13:47 pm
hey everybody,
so here's my problem.. i edited this spot as dvcprohd 1080i60 29.97... just how it was shot.. everything went smoothly but now i need to make an sd version.
i have a blackmagic extreme card and i was planning to convert the footage to our usual sd digibeta layback format blackmagic uncompressed 10 bit 29.97. (i have to lay this to tape)
so i exported the footage "as is" from my hd sequence and placed it on my bm uncompressed 10 bit sequence and resized to do a center cut. i'm getting this very noticeable flicker with movement on my ntsc monitor... when i import the clip into fcp a shift fields filter is added automatically but none of the different settings seem to help.
i tried converting to uncompressed 10bit in compressor but not much difference was achieved... is there a proper way to do this conversion?
thank you in advance..
Shane Ross
Re: dvcpro hd to sd conversion problem
on Jun 15, 2010 at 11:23:29 pm
Why are you doing this? You do know that your capture card can downconvert in real time as you output, right? Fast, good quality...no conversion time.
Shane
