cartoon effect seems to slow things down
Kai Mariah
on Jun 15, 2010 at 1:02:27 pm
Hi.
I'm been working on a project in Final Cut Pro 6.0. Basically I'm using still photos and some video as a background and overlaying my animation on top of that.
To get the background to blend better with the animation, I'm applying a cartoon filter (from NewBlue Free Effects).
For the most part I'm not having a problem with it. However, it doesn't seem to like a few photos. Once the filter is applied to those photos, everything is really slow -- every little movement of the mouse causes the pinwheel to appear.
Why is it doing that and how do I fix it?
Thanks.
Kai
Rafael Amador
Re: cartoon effect seems to slow things down
on Jun 15, 2010 at 1:08:35 pm
[Kai Mariah] " However, it doesn't seem to like a few photos. Once the filter is applied to those photos, everything is really slow -- every little movement of the mouse causes the pinwheel to appear. "
You mean once the effect has been rendered?
rafael
http://www.nagavideo.com
Dave LaRonde
on Jun 15, 2010 at 3:40:57 pm
[Kai Mariah] "...it doesn't seem to like a few photos. Once the filter is applied to those photos, everything is really slow..."
What are H&V dimensions of these few photos?
Dave LaRonde
Sr. Promotion Producer
Kai Mariah
on Jun 15, 2010 at 4:47:04 pm
On the file I'm working on right now it's a 3MB file. Under get info, it lists the dimensions as 3008 x 2000.
