QT update causing issues
Matt Kerstein
on Jun 11, 2010 at 6:28:52 pm
Having export issues after a quicktime update. System that works properly is at OSX 10.4.11 and Quicktime ver 7.6.4. with AJA KONA LHe ver 6.0.1
When I export from other two systems running OSX 10.5.8 quicktime 7.6.6 I get vertical lines in quicktime exports. How to a back track to the those previous versions?
Thank You
Aloha & Mahalo from Maui
Jeremy Garchow
Re: QT update causing issues
on Jun 11, 2010 at 6:40:10 pm
I would export a reference movie, and do this process in Compressor. Much better quality, or use your Kona card to capture in real time to DVCPro HD.
Jeremy
Matt Kerstein
on Jun 11, 2010 at 7:16:06 pm
Thanks Jeremy..gonna compare from previous exports to compressor version...still would like to troubleshoot why a custom export throws these strange vertical "jaggies". Perhaps a HDV component that is updated within QT 7.6.6 but not bundled within 7.6.4?
Jeremy Garchow
on Jun 11, 2010 at 7:20:40 pm
Custom QT exports are bever very good from FCP, and QT COnversion, forget about it.
It's just not a solid workflow, but COmpressor does a very nice job and if you setup a virtual cluster on a multiple core MacPro, it can even go very fast.
Jeremy
