Log and Capture Window Won't Quit
Christopher Bahls-Mariles
on Jun 8, 2010 at 7:26:20 pm
I'm in the process of making a Cuban Digital Archive and have 20+ years of footage on VHS and other analog formats.
I keep running into an issue with the Capture Window in FCP 7 where it will roll to completion but never quit. When looking into the FCP capture scratch, a Quicktime Movie file is created but cannot be read by either FCP or Quicktime.
I've deleted the FCP preferences and restarted, and that has not worked. Any suggestions?
UPDATE:
I have a Canopus ADVC110 device that is converting the analog signal to a digital signal. Input is from the VCR out put is to the computer by firewire. Within FCP, my capture settings is set to "non-controllable device" and I opened the project using easy setup DV-NTSC. I hope the extra information helps.
I'm still looking at a frozen window with a message that reads: "Capturing Clip - NOW CAPTURING (press 'esc' to stop)".
The VHS has stopped rolling for awhile now.
-Chris
