AVCHD disc burn in FCP7
Reinhard Lorenz
on Jun 8, 2010 at 5:44:27 pm
how do I burn an AVCHD disc after FCP has rendered my h264 AVCHD and ac3 files, using Share and 'burn to BLuRay disc'?
Although the manual says I will be prompted to insert a disc and it will burn it, it didn't. I'm on FCP 7.0.2 with a standard built in DVD burner.
Thank you!
Reinhard
Michael Sacci
Re: AVCHD disc burn in FCP7
on Jun 8, 2010 at 7:05:49 pm
This is a job for Compressor not FCP. If you have the files in the formats like AVCHD and ac3 you should not be in FCP.
Arnie Schlissel
on Jun 8, 2010 at 7:43:30 pm
[Reinhard Lorenz] "I'm on FCP 7.0.2 with a standard built in DVD burner. "
If you want to burn a Blu-Ray disk, you need a Blu-Ray burner. Either you would replace the DVD burner in your Mac, or you'd buy an external FW or USB burner.
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
gerwyn bowen
on Jun 8, 2010 at 8:44:29 pm
No you can burn an avchd disc on red laser media (you are limited to 20 mins on DVD-5 approx). There's a tutorial on kenstone.net I think that walks you through it!
Reinhard Lorenz
on Jun 9, 2010 at 5:47:39 pm
Michael, Arnie, Gerwyn,
thanks for your feedback! I went to Kenstones tutorial
http://www.kenstone.net/fcp_homepage/burn_br_mac_superdrive_stone.html
which was very helpful.
Reinhard
