Panasonic MXF p2 import issue - no video
Yann Laforest
on Jun 8, 2010 at 4:28:22 pm
I tried to import Panasonic MXF p2 material into FCP 6.0 and the application seems unable to display the frames (white images). However, the audio loaded fine.
I first thought that there was a codec issue but the same MXF p2 sequences load fine (video and audio) in the Panasonic P2 viewer software installed on the same computer.
Would somebody know what could be the problem here?
I am on MAC PR0 OS 10.5.8 Intel XEON dual 2.6 4GB RAM.
Regards,
Viper
Jeremy Garchow
Re: Panasonic MXF p2 import issue - no video
on Jun 8, 2010 at 4:42:34 pm
Avc-Intra? You are using Log and transfer?
If so, you need to download the AVC-I codec from Panasonic. FCP7 doesn't need this codec as Apple wrote a decoder for the suite.
https://eww.pavc.panasonic.co.jp/pro-av/support/desk/e/download.htm#quickti...
Shane Ross
on Jun 8, 2010 at 5:53:54 pm
Yeah...you need to use LOG and TRANSFER...the proper P2 workflow.
P2 Workflow with FCP 6
OR, you can buy third party solutions like MXF4MAC or Calibrated or Raylight.
Shane
Yann Laforest
on Jun 9, 2010 at 12:27:36 pm
Hi guys,
Yes, it is AVC-Intra.
After installing the Panasonice AVC-Intra codec on the box (as Jeremy suggested), I have been able to load the media in FCP through the LOG and TRANSFER module.
It works like a charm now.
Big thanks for your help,
Regards,
Yann
Jeremy Garchow
on Jun 9, 2010 at 3:34:12 pm
Glad you're up and running.
Jeremy
