Color Smooth Natress for Green Screen
Josh Thomson
on Jun 8, 2010 at 12:52:12 am
Hi there, I am living in a PAL country and have always had issues with the jagged edges from DV greenscreening
I recently searched and found that FCP's Color smoothing greatly reduced this jagged edge - even though it only has 411 and 422, not pal 420
I also recently tried Natress's G Nicer, which seems to do a similar job with its 420 setting
Just wanted to know -
Is the G Nicer filter the same as his Chroma Smoother 420?
And is the Chroma smoother only for Apple's Color?
cheers
Michael Gissing
Re: Color Smooth Natress for Green Screen
on Jun 8, 2010 at 1:14:56 am
[Josh Thomson] "Just wanted to know -
cheers"
I am sure you can find out by visiting the Nattress web site
http://www.nattress.com/Products/products.htm
Rafael Amador
on Jun 8, 2010 at 1:37:55 am
Hi Josh,
Nicer works only for 411.
The Nattress filter you need is "Chroma Smooth/Sharpen".
Works for 411/420 and 422.
It comes in the "Nattress Film effects" pack.
rafael
http://www.nagavideo.com
Josh Thomson
on Oct 21, 2010 at 1:46:37 am
Thank you so much for your help.
Much, much appreciated.
