can't import CS5 psd files into FCP
melissa kern
on Jun 2, 2010 at 11:06:09 pm
hi
having a major issue. I created text inside After Effects CS5
and exported as a psd
then tried to open in FCP 6.6
and I get this error message
FILE ERROR: 1 file(s) recognized, 0 access denied, 1 unknown
what's happening?
oh the files all have transparent backgrounds.. is that a problem (the alpha channel?)
I've searched the forum, but can't tell if this issue hsa been covered.
thanks
m
Dave LaRonde
Re: can't import CS5 psd files into FCP
on Jun 2, 2010 at 11:13:42 pm
As long as you haven't done anything fancy, Photoshop should let you save as an earlier version. What happens if you do so?
Dave LaRonde
Sr. Promotion Producer
Mike Schrengohst
on Jun 3, 2010 at 3:20:57 am
Rafael Amador
on Jun 3, 2010 at 5:02:55 am
If the files have been created in a PC, open them in a Mac and save it again.
rafael
http://www.nagavideo.com
Bjarki Gudjonsson
on Jun 4, 2010 at 9:35:38 am
If you go to the Image menu and the Mode submenu, make sure the images are RGB and 8 bit. FCP won't play nice with images that are 16 or 32 bit.
