Problem w/ Canon HV40 as Capture Deck
Carlton Wing
on Jun 2, 2010 at 3:09:23 am
I just purchased a Canon HV40 to use as a capture deck for FCP and an extra camera on shoots. The import is fine, but rarely can I "batch capture" into FCP because I frequently get an "error" reading and have to try the capture again. If I have 8 items in a batch, it may take 20-25 attempts before they all get in. It seems like the deck won't lock down on the start point on the tape.
Has anyone else encountered this?
Is it a problem in FCP settings?
or is the Canon inadequate as a capture device?
Many thanks!
Joe Paolo
Re: Problem w/ Canon HV40 as Capture Deck
on Jun 2, 2010 at 1:45:39 pm
My HV20 has been mosty fine with only the occasional TC hiccup. Canons can be iffy with non-canon tapes. Have you run a cleaning tape thru it?
joe
editmojo.com
Carlton Wing
on Jun 2, 2010 at 8:03:06 pm
I've not run a cleaning tape through it since it is brand new. I'll give it a try.
Right now I'm using Maxell tapes. I also use Sony.
Joe Paolo
on Jun 2, 2010 at 9:41:20 pm
No. I meant tapes shot on non-Canon cameras sometimes don't play well on Canons. My HV20 is solid with any Canon HDV and 70-30 with HDV tapes from a Sony. Good luck
joe
editmojo.com
Carlton Wing
on Jun 2, 2010 at 10:02:58 pm
It was a mix. Some were shot on Canon (including the same HV40) and others on Sony. Same results, no noticeable difference between the two.
