240fps
Kevin Thorne
240fps
on May 31, 2010 at 10:14:50 am
I need to be able to save clips that I am creating in LiveType & Motion at 240fps (I know it's high, but that's what the signs I'm developing for require). I seem to be unable to do this - can you suggest a way to do this?
I'm using FCP 6 / OSX 10.5.8
thanks!
Rafael Amador
Re: 240fps
on May 31, 2010 at 11:05:32 am
Hi Kevin,
240 fps is not an standard time-base.
I don't think you will find anything that render more than 60fps.
rafael
http://www.nagavideo.com
Kevin Thorne
easier way?
on May 31, 2010 at 11:08:55 am
I can save livetype at 99fps, but I do need to go to 240fps. That's what this software requires.
Rafael Amador
Re: easier way?
on May 31, 2010 at 12:10:56 pm
In Motion you can set manually till 150fps.
Try AE or Shake.
rafael
gary adcock
Re: easier way?
on May 31, 2010 at 3:03:05 pm
[Kevin Thorne] "I can save livetype at 99fps, but I do need to go to 240fps. That's what this software requires."
Kevin, could you comment on what you are doing?
I have never ever heard of any device requiring 240 Frames per second? (not one of my military clients go beyond 72 fps for PLAYBACK)
are you sure that you do not have the frame rate and display frequency screwed up?
Video playback is usually at 50hrz or 60hrz- that is not the frame rate- that is the refresh rate of the display.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, IL
http://blogs.creativecow.net/24640
Dave LaRonde
Re: easier way?
on May 31, 2010 at 4:33:14 pm
I'm with Gary -- more information, please.
If you can expand on your delivery requirements, how your deliverable is going to be used, and why either you or your client regard such a high frame rate as necessary, it'll help a lot.
Dave LaRonde
Sr. Promotion Producer
Kevin Thorne
Re: easier way?
on May 31, 2010 at 4:39:29 pm
I was given the specs of 288px x 288px for a 10ft square sign at 240fps. I've been supplying them at 99fps but have been asked to increase this. I know the px size is tiny for the viewing area size, but they look great from 100ft+ away which is where they're seen from.
I'm waiting to speak with the sign makers directly. As soon as I hear from them, I'll respond further with more details.
thanks.
Rafael Amador
Re: easier way?
on May 31, 2010 at 11:56:12 pm
But, which device will play that file?
How will you display a 240fps video signal?
I don't understand the purpose.
rafael
Kevin Thorne
Re: easier way?
on Jun 1, 2010 at 12:14:06 pm
I don't understand it either, but I've managed to get a 240fps conversion, and the client says it works perfectly.
thanks everyone for your help in this.
B.J. Ahlen
Re: 240fps
on May 31, 2010 at 2:36:52 pm
Signs?
Are you thinking to use a "240 Hz" HDTV?
If so, I don't think they can take a 240 fps input (I wish they did, because then we could fast forward in editing with a quality like a flatbed, gotta say I miss that sometimes...).
What they do is take 30 or 60 fps and create intermediate frames to create a smoother motion.
