motion clip failing to render
anthony Faulkner
on May 28, 2010 at 12:06:04 pm
I am pulling my hair out. This isn't the first time this has happened.
I complete a motion3 clip That is three group clip
emitter at the rear, text in the middle and another emitter at the front.
I Copy it into FCP6.0. It looks fine in the viewer. I put it in the timeline, it looks fine unrendered. I render it and half way through the front emitter group just disappears. it rolls back like a moving crop.
I try changing the original motion clip and resaving it, reloading it. exactly the same thing happens.
I am not sure what to do here...
Any suggestions??
Jerry Hofmann
Re: motion clip failing to render
on May 28, 2010 at 12:19:04 pm
Export the clip as a QuickTime movie from Motion and import that file into FCP to cut into the sequence.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
