FCP cannot open files in the "Final Cut Pro XML File" format
Mark Hubert
on May 23, 2010 at 3:35:27 am
I "sent" a sequence to Soundtrack Pro 3 for a mix. I then exported with the after export open in FCP sequence option selected.
When it's complete I get the error: The document "mastermix.xml" could not be opened. Final Cut Pro cannot open files in the Final Cut Pro XML File" format."
Is this a joke?
I've done this as both mono track and stereo mix.
These are the steps in the Soundtrack Pro User Manual.
Guidance Appreciated.
Mark
Mark Hubert
Re: FCP cannot open files in the "Final Cut Pro XML File" format
on May 23, 2010 at 3:41:07 am
OK....
I just went into FCP and Import XML chose the mastermix.xml file and it worked.
Mark Hubert
on May 23, 2010 at 4:47:17 am
And now FCP is totally unstable and crashing when I do import the XML.
It creates another sequence with the old tracks disabled (as the UM says it does) Start working with it and it crashes.
