Which prefs file determines the default multiclip mode?
John Adams
on May 23, 2010 at 2:40:54 am
A challenge to all tinkerers out there --
I want to change the default multiclip mode (ie. the default selection in the dropdown menu in the dialog box that appears when you 'make multiclip'). I want to change it from In Point to Timecode.
I don't know of any way of changing this via the GUI -- so I figure it must be controlled by a line of script hidden away somewhere in one of the prefs or config files...
I've had a quick look at some of the pref files using pList Editor, hoping to find something obvious to tweak --- but I'm no codehead, so I'm probably not looking in the right place.
Anyone have any hints where it might be listed? Or, is there a different way to achieve this?
cheers
FCP 6.0.6 // OSX 10.5.8 // 2.66 Quad Mac Pro
http://www.tinypalace.net
Tom Wolsky
Re: Which prefs file determines the default multiclip mode?
on May 23, 2010 at 3:55:52 am
It's not a preference. It must be in the application code. Tinkering with that is a violation of the EULA.
All the best,
Tom
Class on Demand DVDs "Complete Training for FCP7," "Basic Training for FCS" and "Final Cut Express Made Easy"
Author: "Final Cut Pro 5 Editing Essentials" and "Final Cut Express 4 Editing Workshop"
John Adams
on May 23, 2010 at 4:20:13 am
cheers for the reply, Tom.
That's too bad -- I thought it might've been similar to After Effects which allows some of its UI setup to be tweaked via its pref files.
thanks
