Prores 59.94 fps
Steve Brame
Prores 59.94 fps
on May 21, 2010 at 9:08:31 pm
I've been handed a Prores 1280*720 59.94fps file to author to DVD. There appears to be no field dominance, so I'm assuming(dangerously) that this means the file is progressive? For best final quality, should my MPEG be progressive as well?
Steve Brame
creative illusions Productions
Walter Soyka
Re: Prores 59.94 fps
on May 22, 2010 at 4:24:40 pm
All 720-line HD formats are progressive; there is no such thing as 720i. You can safely assume that the footage is progressive.
You cannot safely assume that the true frame rate is 59.94 fps, though. It could also be 29.97 fps (doubled) or 23.976 fps (with something like 3:2 pulldown, just across entire frames instead of fields). If you step through the footage frame by frame, it should be pretty clear.
If the footage is truly 59.94 fps, you might preserve some of the motion by compressing to 29.97 interlaced fps. If it's 23.976, you can reverse-telecine and compress at 23.976 fps.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
© 2018 All Rights Reserved
