Capturing in FCP 6 Off lining in FCP 4 HD - Audio captured in 6 not showing up in 4
ian shand
on May 21, 2010 at 12:48:36 pm
This may seem an odd question but, here goes. As a College we have just initiated a new procedure for editing. Students capture and off-line to an ext FW HD, All files are captured as DVCam PAL 48Khz. When the off-line is completed they then copy the files and projects to Editshare to do an online. At the moment we are either going between FCP 4 HD to FCP 6 with no problems. The problem comes when we capture on FCP 6 then import the media into FCP 4 HD (to do the off-line), the clips come in and no audio is recognised. The clips are captured with audio, the audio plays back in QT and in MPEG stream clip. A DVPAL Export from stream clip and re-import restores the audio.
Can anyone think of any reason why the audio disappears when we import of FCP 4 HD?
John Pale
Re: Capturing in FCP 6 Off lining in FCP 4 HD - Audio captured in 6 not showing up in 4
on May 21, 2010 at 5:27:41 pm
FCP 4 and earlier did not support muliple (more than 2) audio tracks. Changes in FCP and Quicktime for FCP 5 and up, to allow multiple audio tracks cause this behavior.
ian shand
on May 24, 2010 at 1:21:01 pm
Thanks, yep that makes sense, I've not really used FCP before V5, so it wasn't something I've dealt with before.
Ian
