Batch Export Clips from timeline??
Jared Kay
on May 21, 2010 at 12:40:03 pm
I have over 100 separate physician interviews in need of web export. I have created sequences (timelines) labeled Day1, Day2, etc... with 5-10 separate interviews on each timeline.
I am now needing to export these to a web capable format..
I have scoured the web for a solution to a batch export option, and so far, no luck..
I can't be asking too much from final cut, right?
Specs:
Final Cut Pro 6
Canon 7d H264 (1080, 30fps)
Arnie Schlissel
Re: Batch Export Clips from timeline??
on May 21, 2010 at 2:50:39 pm
Look up "Batch Export" in your FCP manual. It will have all of the steps you need to do this.
You can also export your sequences to Compressor as a batch. Select them all, right click & choose Export via Compressor.
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
Jared Kay
on May 21, 2010 at 8:09:15 pm
A standard batch export is no problem...
The issue is batch exporting multiple separate clips from a single timeline...
John P  Isaza
on Oct 27, 2010 at 11:08:17 pm
I have the same question did you find a way to do it?
Jared Kay
on Nov 5, 2010 at 1:15:42 pm
I did find a round-abut way...
I now copy/paste each segment to a new sequence... and then highlight and right click on all sequences in the bin, and selecting "batch export"
For instance...
My Timeline:
///segment1//// ///segment2//// ///segment3////
New Sequence 1:
///segment1////
New Sequence 2:
///segment2////
...etc
Hope this helps....
Jared Kay
http://www.amplified-media.com
