Final Cut Pro 7 won't load....tried usual steps with no luck
Darrell Schuur
on May 20, 2010 at 1:21:57 am
So I have final cut pro 7 on iMac intel and it has been working fine until i tried to open it today. There was a Java software update that I did last night which was the only difference in the system. I did the usual tricks of repairing the permissions and deleting the preferences and cache and still have the same problem of it not opening. I did get it to open a couple times but it looks like it's trying to boot from a firewire which i don't have instead of the HD where my files are located. i was able to get one of my timelines up but like i said before it wasn't showing the files as being online. I have projects due tomorrow that I have to make changes to and I really could use some help. Thanks!
Darrell Schuur
Re: Final Cut Pro 7 won't load....tried usual steps with no luck
on May 20, 2010 at 12:15:29 pm
Here is the error message i get when i can't load final cut.
Process: Final Cut Pro [183]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCutPro
Version: 7.0.2 (7.0.2)
Build Info: FCPApp-955601010~8
Code Type: X86 (Native)
Parent Process: launchd [82]
Date/Time: 2010-05-20 08:14:09.063 -0400
OS Version: Mac OS X 10.6.3 (10D573)
Report Version: 6
Interval Since Last Report: 163105 sec
Crashes Since Last Report: 56
Per-App Interval Since Last Report: 82769 sec
Per-App Crashes Since Last Report: 54
Anonymous UUID: 45893B56-A491-48E7-9831-100742880BCF
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000001
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 ??? 0x0b2f4040 0 + 187646016
1 com.apple.FinalCutPro 0x00189c38 GetInfoFromReader(KGFileRec*, KGDictInt*, char*) + 374
2 com.apple.FinalCutPro 0x0018b1f2 pKGFileAddOrCheckImportWithKnownAlias(KGFileSpec*, char*, KGDictInt*, KGFileRec**, KGFileRec**, void*) + 1240
3 com.apple.FinalCutPro 0x0018a5dd pKGFileAdd(KGFileSpec*, char*, KGDictInt*, KGFileRec**) + 57
4 com.apple.FinalCutPro 0x005114ed TemplateFileProc(KGFileSpec*, void*) + 355
5 com.apple.FinalCutPro 0x0019bce6 pKGDirScan(KGFileSpec*, void*, KGDirScanRec*) + 1420
6 com.apple.FinalCutPro 0x0050acee TemplateFolderProc(KGFileSpec*, void*, KGDirScanRec*) + 152
7 com.apple.FinalCutPro 0x0019bc41 pKGDirScan(KGFileSpec*, void*, KGDirScanRec*) + 1255
8 com.apple.FinalCutPro 0x0050ae2f ScanForVideoTemplates(KGFileSpec*, unsigned char) + 269
9 com.apple.FinalCutPro 0x0051121a RegisterQCEffects + 938
10 com.apple.FinalCutPro 0x001cc0a7 KGPlaybackLibAction + 2817
11 com.apple.FinalCutPro 0x002449b6 CallLibs(KGLibActionCode, unsigned char) + 346
12 com.apple.FinalCutPro 0x00244b59 KGFinishLibraries + 115
13 com.apple.FinalCutPro 0x00244c8d KGInit() + 173
14 com.apple.FinalCutPro 0x004128c5 OpenApplication(AEDesc const*, AEDesc*, long) + 73
15 com.apple.AE 0x98cc6f58 aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned long, unsigned char*) + 166
16 com.apple.AE 0x98cc6e57 dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 43
17 com.apple.AE 0x98cc6d61 aeProcessAppleEvent + 197
18 com.apple.HIToolbox 0x96a70487 AEProcessAppleEvent + 50
19 com.apple.HIToolbox 0x96bf13ae AEProcessEvent + 160
20 com.apple.HIToolbox 0x96b02b76 HIStdAppHandler::HandleEvent(OpaqueEventHandlerCallRef*, TCarbonEvent&) + 206
21 com.apple.HIToolbox 0x96b03c64 TEventHandler::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 64
22 com.apple.HIToolbox 0x96a3c0a9 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
23 com.apple.HIToolbox 0x96a3b370 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
24 com.apple.HIToolbox 0x96a3b1cf SendEventToEventTargetWithOptions + 58
25 com.apple.HIToolbox 0x96a6fd10 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 3006
26 com.apple.HIToolbox 0x96a3c4fa DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
27 com.apple.HIToolbox 0x96a3b370 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
28 com.apple.HIToolbox 0x96a5db55 SendEventToEventTarget + 52
29 com.apple.HIToolbox 0x96be6df7 ToolboxEventDispatcher + 86
30 com.apple.HIToolbox 0x96be6f2f RunApplicationEventLoop + 243
31 com.apple.FinalCutPro 0x0015396f KGMainEvent(void*) + 51
32 com.apple.FinalCutPro 0x002c10e8 main + 54
33 com.apple.FinalCutPro 0x00002d7b _start + 209
34 com.apple.FinalCutPro 0x00002ca9 start + 41
Thread 1:
0 libSystem.B.dylib 0x97a84bd2 __workq_kernreturn + 10
1 libSystem.B.dylib 0x97a85168 _pthread_wqthread + 941
2 libSystem.B.dylib 0x97a84d86 start_wqthread + 30
Thread 2: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x97a85b42 kevent + 10
1 libSystem.B.dylib 0x97a8625c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x97a85719 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x97a854be _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x97a84f41 _pthread_wqthread + 390
5 libSystem.B.dylib 0x97a84d86 start_wqthread + 30
Thread 3:
0 libSystem.B.dylib 0x97a7e286 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x9373982d __CFSocketManager + 1085
2 libSystem.B.dylib 0x97a8ca19 _pthread_start + 345
3 libSystem.B.dylib 0x97a8c89e thread_start + 34
Thread 4:
0 libSystem.B.dylib 0x97a5f342 semaphore_wait_signal_trap + 10
1 libSystem.B.dylib 0x97a8ceb8 _pthread_cond_wait + 1089
2 libSystem.B.dylib 0x97ad542f pthread_cond_wait + 48
3 com.apple.FinalCutPro 0x0043e785 Synchronizable::Wait() + 53
4 com.apple.FinalCutPro 0x00428d6f DisplayQueue::Run() + 681
5 com.apple.FinalCutPro 0x0046a772 Thread::RunHelper(void*) + 20
6 libSystem.B.dylib 0x97a8ca19 _pthread_start + 345
7 libSystem.B.dylib 0x97a8c89e thread_start + 34
Thread 5:
4 com.apple.FinalCutPro 0x004e594f WorkUnitPerformer::Run() + 55
Thread 6:
0 libSystem.B.dylib 0x97a8d262 __semwait_signal + 10
1 libSystem.B.dylib 0x97a8cf1e _pthread_cond_wait + 1191
2 libSystem.B.dylib 0x97a8ebb8 pthread_cond_wait$UNIX2003 + 73
3 ....Helium.HSmoothMotionRender 0x0d842f52 HSmoothMotionRenderFactory + 921506
4 ....Helium.HSmoothMotionRender 0x0d762391 HSmoothMotionRenderFactory + 993
5 ....Helium.HSmoothMotionRender 0x0d76241e HSmoothMotionRenderFactory + 1134
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x0a752b00 ebx: 0x0a9747a9 ecx: 0x93816580 edx: 0x00000020
edi: 0x00000000 esi: 0x002811ba ebp: 0xbfffcf38 esp: 0xbfffcd48
ss: 0x0000001f efl: 0x00010246 eip: 0x0b2f4040 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000001
Binary Images:
0x1000 - 0x86effc com.apple.FinalCutPro 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
0xc2b000 - 0xc2eff7 +KGCore ??? (???) /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
0xc36000 - 0xc36ff7 com.apple.iokit.dvcomponentglue 1.9.9 (1.9.9) /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
0xc3a000 - 0xc49fff com.apple.AERegistration 1.2 (77) /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
0xc5d000 - 0xc64fff com.apple.AEProfiling 1.2 (22) /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
0xc6e000 - 0xe22feb com.apple.prokit 5.1 (917) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
0xee1000 - 0xf53fef com.apple.ProFX 1.2.3 (1.2.3) /Library/Application Support/ProApps/SharedA/Frameworks/ProFX.framework/Versions/A/ProFX
0xf75000 - 0xfd0ffb com.apple.proapps.MIO 1.0.4 (505) /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
0x100c000 - 0x1015ff7 com.apple.finalcutstudio.prometadatasupport 0.6 (1.0) /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
0x101d000 - 0x1057fff com.apple.CoreMediaIOServicesPrivate 30.0 (1001) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
0x1073000 - 0x109cff7 com.apple.CoreMediaPrivate 20.0 (20.0) /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
0x10af000 - 0x10e2ff3 com.apple.FWAVCPrivate 30.46 (46) /System/Library/PrivateFrameworks/FWAVCPrivate.framework/Versions/A/FWAVCPrivate
0x10f7000 - 0x1115fef com.apple.XSKey 1.0.0 (52) /Library/Frameworks/XSKey.framework/Versions/A/XSKey
0x1124000 - 0x11d9fe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) /usr/lib/libcrypto.0.9.7.dylib
0x1263000 - 0x12a3ff7 com.apple.vmutils 4.2 (106) /System/Library/PrivateFrameworks/vmutils.framework/vmutils
0x9580000 - 0x9588ff7 com.apple.proapps.mrcheckpro 1.4 (385) /Applications/Final Cut Pro.app/Contents/Resources/MRCheckPro.bundle/Contents/MacOS/MRCheckPro
0x95fb000 - 0x95ffff3 com.apple.FinalCutPro.Plugins.AudioGroupsExport 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
0x961c000 - 0x963ffe7 GLRendererFloat ??? (???) /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x9647000 - 0x964cfff com.apple.FinalCutPro.Plugins.Cache Manager 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
0x9651000 - 0x9652fff com.apple.FinalCutPro.Plugins.Text Window 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
0x9e9c000 - 0xa00ffe7 GLEngine ??? (???) /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0xa041000 - 0xa405fff com.apple.ATIRadeonX2000GLDriver 1.6.10 (6.1.0) /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLDriver
0xa432000 - 0xa444fff com.apple.motion.Text 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Text.ozp/Contents/MacOS/Text
0xa454000 - 0xa47eff7 com.apple.FinalCutPro.Plugins.AfterEffects 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
0xa486000 - 0xa49dff3 com.apple.FinalCutPro.Plugins.AudioMixer 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
0xa4a8000 - 0xa4d2feb com.apple.proapps.ControlSurfaceSupport 2.0 (68) /Applications/Final Cut Pro.app/Contents/Frameworks/ControlSurfaceSupport.framework/Versions/A/ControlSurfaceSupport
0xa4f3000 - 0xa4fbfff com.apple.FinalCutPro.Plugins.Effect Builder 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
0xa600000 - 0xa64cff3 com.apple.audio.midi.CoreMIDI 1.7 (42) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0xa671000 - 0xa749ff2 com.apple.FinalCutPro.Plugins.Browser 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
0xa767000 - 0xa781fff com.apple.FinalCutPro.CinemaTools 5.0 (5.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
0xa78d000 - 0xa797ff9 com.apple.FinalCutPro.Plugins.CTHelper 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
0xa79e000 - 0xa7c4ff7 com.apple.FinalCutPro.Plugins.EditTape 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
0xa7d3000 - 0xa82eff5 com.apple.FinalCutPro.Plugins.EDL Export 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
0xa843000 - 0xa84effe com.apple.FinalCutPro.Plugins.FCPExtPluginSupport 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
0xa857000 - 0xa88aff7 com.apple.FinalCutPro.Plugins.FCS Engine 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
0xa894000 - 0xa8a5ff7 com.apple.FinalCutPro.Plugins.FilterCustomEd 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
0xa8ab000 - 0xa8c0ffb com.apple.FinalCutPro.Plugins.FilterViewer 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
0xa8c6000 - 0xa8c9ffc com.apple.FinalCutPro.Plugins.FinalTouchExport 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FinalTouchExport.bundle/Contents/MacOS/FinalTouchExport
0xa8cf000 - 0xa8edfea com.apple.FinalCutPro.Plugins.Flash 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
0xa8f9000 - 0xa906ffb com.apple.FinalCutPro.Plugins.GenViewer 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
0xa90c000 - 0xa910fff com.apple.FinalCutPro.Plugins.LayerFileReader 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
0xa915000 - 0xa961ff3 com.apple.FinalCutPro.Plugins.Media Manager 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
0xa96b000 - 0xa97dff0 com.apple.FinalCutPro.Plugins.MolokiniSupport 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
0xa98c000 - 0xa9a0fff com.apple.FinalCutPro.Frameworks.MolokiniTranslation 1.0 (1.0) /Applications/Final Cut Pro.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
0xa9ae000 - 0xa9e0ffb com.apple.FinalCutPro.Plugins.Motion Viewer 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
0xa9f1000 - 0xaa0cff3 com.apple.FinalCutPro.Plugins.Movie Analyzer 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
0xaa1b000 - 0xaa31ffb com.apple.FinalCutPro.Plugins.Movie Viewer 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
0xaa3d000 - 0xaa41fff com.apple.FinalCutPro.Plugins.NuggetExport 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
0xaa46000 - 0xaafffe7 com.apple.FinalCutPro.Plugins.OMF Audio Export 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
0xab12000 - 0xab1affb com.apple.FinalCutPro.Plugins.Perf Analyzer 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
0xab1f000 - 0xab34ffb com.apple.FinalCutPro.Plugins.ProAppsIntegration 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/ProAppsIntegration.bundle/Contents/MacOS/ProAppsIntegration
0xab44000 - 0xab51ff7 com.apple.FinalCutPro.Plugins.Pulldown Support 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
0xab59000 - 0xab98fef com.apple.FinalCutPro.Plugins.QTM Reader 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
0xaba5000 - 0xabadff3 com.apple.FinalCutPro.Plugins.QuickView 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
0xabb2000 - 0xabc2ffe com.apple.FinalCutPro.Plugins.Relink Media 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
0xabc9000 - 0xac62ff2 com.apple.FinalCutPro.Plugins.Timeline Editor 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
0xac71000 - 0xac82fff com.apple.FinalCutPro.Plugins.Transcoder 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
0xac8c000 - 0xac9efff com.apple.FinalCutPro.Plugins.Transition Viewer 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
0xaca4000 - 0xacb9ff3 com.apple.FinalCutPro.Plugins.Trimming 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
0xacbf000 - 0xacc5ffb com.apple.FinalCutPro.Plugins.VDUSupport 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
0xaccb000 - 0xacccffb com.apple.FinalCutPro.Plugins.Vector Accelerator 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Vector Accelerator.bundle/Contents/MacOS/Vector Accelerator
0xacd1000 - 0xace2fff com.apple.FinalCutPro.Plugins.VideoLog 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
0xace7000 - 0xacffff7 com.apple.FinalCutPro.Plugins.VoiceOver 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
0xad06000 - 0xad83fe1 com.apple.FinalCutPro.Plugins.XML Support 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
0xb500000 - 0xb514fef com.apple.fcp.DVOutputUnit 1.3 (1.3) /Applications/Final Cut Pro.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
0xb888000 - 0xbc6efe3 QuickTimeH264.scalar ??? (???) /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
0xbcca000 - 0xbce3fe7 com.apple.applepixletvideo 1.2.19 (1.2d19) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0xbce8000 - 0xbd24fe3 com.apple.QuickTimeFireWireDV.component 7.6.6 (1729) /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0xbd85000 - 0xbd89ff3 com.apple.SmoothCamFxPlug 1.0.1 (1.0.1) /Library/Application Support/ProApps/SharedA/Plug-Ins/FxPlug/SmoothCam.fxplug/Contents/MacOS/SmoothCam
0xbda3000 - 0xbdbcfff com.apple.promath.framework 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProMath.framework/Versions/A/ProMath
0xbdc6000 - 0xbdddfe7 libedit.2.dylib 2.11.0 (compatibility 2.0.0) /usr/lib/libedit.2.dylib
0xbdea000 - 0xbdfbfff com.apple.RetimingMath 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/RetimingMath.framework/Versions/A/RetimingMath
0xbe89000 - 0xbe8aff7 com.apple.Helium 3.0.2 (352) /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Helium
0xbe8f000 - 0xbe91ff7 Motion 726.0.0 (compatibility 1.0.0) /Library/Frameworks/Motion.framework/Versions/A/Motion
0xbe98000 - 0xbed0fff com.apple.motion.MotionBundle 4.0.2 (726) /Library/Application Support/ProApps/Bundles/Motion.bundle/Contents/MacOS/Motion
0xbee4000 - 0xbef3ff7 com.apple.QuartzComposer.FxPlugWrapper 1.2.3 (92) /Library/Application Support/ProApps/SharedA/Plug-Ins/ProFX/FxPlugWrapper.plugin/Contents/MacOS/FxPlugWrapper
0xbff2000 - 0xbff3fff com.apple.FxHeliumImage 4.0.0 (1.0) /Library/Application Support/ProApps/SharedA/Frameworks/FxHeliumImage.framework/Versions/A/FxHeliumImage
0xbff9000 - 0xbffbfff com.apple.Helium.HCache 2.1.0 (352) /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Plug-ins/HCache.bundle/Contents/MacOS/HCache
0xc161000 - 0xc16dfff com.apple.PluginManager 1.7.3 (34) /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
0xc17a000 - 0xc18bff7 com.apple.fxplugframework 1.2.3 (1.2.3) /Library/Frameworks/FxPlug.framework/Versions/A/FxPlug
0xc307000 - 0xc405ff7 com.apple.soundtrackpro.integration 3.0 (3.0) /Library/Application Support/ProApps/Bundles/Soundtrack Pro Integration.bundle/Contents/MacOS/Soundtrack Pro Integration
0xc436000 - 0xc4d3ff8 com.apple.procore.framework 4.0.2 (757) /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
0xc513000 - 0xc51bff7 com.apple.QuartzComposer.QCMotionPatch 1.0 (726) /Library/Application Support/ProApps/SharedA/Plug-Ins/ProFX/QCMotionPatch.plugin/Contents/MacOS/QCMotionPatch
0xc564000 - 0xc575fc7 +com.newblue.filmeffects.mac.plugin.fxplug 1.0 (1) /Library/Plug-Ins/FxPlug/NewBlue/Film Effects/FilmEffects.fxplug/Contents/MacOS/FilmEffects
0xc585000 - 0xc5bbffa com.apple.proinspector.framework 4.0.2 (761) /Library/Application Support/ProApps/SharedA/Frameworks/ProInspector.framework/Versions/A/ProInspector
0xc5de000 - 0xc5e3ffb com.apple.fxmetaplug.ImageUnit 1.2.2 (1.2.2) /Library/Application Support/ProApps/Internal Plug-Ins/FxMetaPlug/ImageUnit.fxmetaplug/Contents/MacOS/ImageUnit
0xc700000 - 0xc764fe2 com.apple.LiveType.framework 2.1.4 (2.1.4) /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
0xc7e1000 - 0xc82cff4 com.apple.Bloodhound 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/Bloodhound.framework/Versions/A/Bloodhound
0xcb00000 - 0xcc52fec com.apple.Helium.HeliumRender 2.0.2 (352) /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
0xccab000 - 0xcf15fe2 com.apple.motion.filters 4.0.2 (601) /Library/Application Support/ProApps/SharedA/Plug-Ins/FxPlug/Filters.bundle/Contents/MacOS/Filters
0xcfce000 - 0xd641fe0 +com.newblue.filmeffects.mac.library 1.0 (1.0) /Library/Application Support/NewBlue/Film Effects for Mac/FilmEffectsMac.bundle/Contents/MacOS/FilmEffectsMac
0xd75e000 - 0xd86efef com.apple.Helium.HSmoothMotionRender 1.0.3 (352) /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Plug-ins/HSmoothMotionRender.bundle/Contents/MacOS/HSmoothMotionRender
0xd88a000 - 0xd9a3ff2 com.apple.Helium.HDominantMotionTracker 2.0.1 (352) /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Plug-ins/HDominantMotionTracker.bundle/Contents/MacOS/HDominantMotionTracker
0xdc00000 - 0xe4e1fe2 com.apple.ozone.framework 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/Ozone.framework/Ozone
0xe983000 - 0xea56fff org.python.python 2.5.4 (2.5) /System/Library/Frameworks/Python.framework/Versions/2.5/Python
0xea96000 - 0xebfeff2 com.apple.ProMedia 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProMedia.framework/Versions/A/ProMedia
0xec6f000 - 0xecd9ff2 com.apple.ProGraphics 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProGraphics.framework/Versions/A/ProGraphics
0xedf6000 - 0xef7afe2 com.apple.Lithium 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Frameworks/Lithium.framework/Versions/A/Lithium
0xf001000 - 0xf0cfff3 com.apple.prochannel.framework 4.0.2 (763) /Library/Application Support/ProApps/SharedA/Frameworks/ProChannel.framework/Versions/A/ProChannel
0xf16e000 - 0xf522ff2 com.apple.motion.TextFramework 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/TextFramework.framework/TextFramework
0xf63c000 - 0xf7d3ff8 com.apple.motion.Behaviors 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Behaviors.ozp/Contents/MacOS/Behaviors
0xf872000 - 0xfa0fff8 com.apple.motion.Particles 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Particles.ozp/Contents/MacOS/Particles
0x10000000 - 0x10060fef com.apple.proapps.AudioMixEngine 2.0 (68) /Applications/Final Cut Pro.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
0x8fe00000 - 0x8fe41627 dyld 132.1 (???) /usr/lib/dyld
0x90003000 - 0x90050feb com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x90051000 - 0x90930ff7 com.apple.AppKit 6.6.5 (1038.29) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x90931000 - 0x90a23ff7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) /usr/lib/libcrypto.0.9.8.dylib
0x90a2b000 - 0x90aa4ff7 com.apple.PDFKit 2.5.1 (2.5.1) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x90aa5000 - 0x90aa5ff7 com.apple.Cocoa 6.6 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x90aba000 - 0x90ac0fff com.apple.CommonPanels 1.2.4 (91) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x90ac1000 - 0x90b01ff3 com.apple.securityinterface 4.0.1 (37214) /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x90b02000 - 0x90d08feb com.apple.AddressBook.framework 5.0.1 (868) /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x90d09000 - 0x90eebfff com.apple.imageKit 2.0.3 (1.0) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x90eec000 - 0x90f63ff3 com.apple.backup.framework 1.2.2 (1.2.2) /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x90f64000 - 0x90f64ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x90f66000 - 0x90f76ff7 com.apple.DSObjCWrappers.Framework 10.6 (134) /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x90f77000 - 0x911e7ffb com.apple.Foundation 6.6.2 (751.21) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x91216000 - 0x9125ffe7 libTIFF.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91260000 - 0x91275ff7 com.apple.iChat.InstantMessage 5.0.2 (745) /System/Library/Frameworks/InstantMessage.framework/Versions/A/InstantMessage
0x91276000 - 0x91733ffb com.apple.VideoToolbox 0.484.5 (484.5) /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x91734000 - 0x91778fe7 com.apple.Metadata 10.6.3 (507.8) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x91779000 - 0x917e3fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) /usr/lib/libstdc++.6.dylib
0x918c8000 - 0x918fcff7 libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) /usr/lib/libssl.0.9.8.dylib
0x918fd000 - 0x9192eff3 libTrueTypeScaler.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x9192f000 - 0x91932fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) /usr/lib/system/libmathCommon.A.dylib
0x91933000 - 0x9193eff7 libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9198e000 - 0x91a58fef com.apple.CoreServices.OSServices 357 (357) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x91a59000 - 0x91a97ff7 com.apple.QuickLookFramework 2.2 (327.4) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x91aba000 - 0x91adafe7 libresolv.9.dylib 40.0.0 (compatibility 1.0.0) /usr/lib/libresolv.9.dylib
0x91adb000 - 0x91bb8ff7 com.apple.vImage 4.0 (4.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91bb9000 - 0x91bbdff7 libGFXShared.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x91bbe000 - 0x91ccaff7 libGLProgrammability.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x91ccb000 - 0x91cd8ff7 com.apple.AppleFSCompression 24.0.1 (1.0) /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x91cfa000 - 0x91dd8fef com.apple.QuickTimeMPEG4.component 7.6.6 (1729) /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
0x91dd9000 - 0x91e74ff7 com.apple.ApplicationServices.ATS 4.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x91e75000 - 0x91ecffe7 com.apple.CorePDF 1.1 (1.1) /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x91ed0000 - 0x91ee1ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91ee2000 - 0x91f03fe7 com.apple.opencl 12.1 (12.1) /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x91f04000 - 0x92032fe7 com.apple.CoreData 102.1 (251) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9203e000 - 0x92066ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) /usr/lib/libxslt.1.dylib
0x92067000 - 0x9209ffe7 libcurl.4.dylib 6.1.0 (compatibility 6.0.0) /usr/lib/libcurl.4.dylib
0x920a0000 - 0x920bbff7 libPng.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x920f8000 - 0x9211efff com.apple.DictionaryServices 1.1.1 (1.1.1) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9211f000 - 0x9215afeb libFontRegistry.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x9215b000 - 0x92336ff3 libType1Scaler.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x92337000 - 0x92562ff3 com.apple.QuartzComposer 4.1 (156.13) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x92563000 - 0x92566ff7 libCGXType.A.dylib 543.33.0 (compatibility 64.0.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x92611000 - 0x926e2fe3 ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x9270a000 - 0x9270aff7 com.apple.CoreServices 44 (44) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x9270b000 - 0x9275cff7 com.apple.HIServices 1.8.0 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x9275d000 - 0x936aefe7 com.apple.QuickTimeComponents.component 7.6.6 (1729) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x936af000 - 0x936bcfe7 libbz2.1.0.dylib 1.0.5 (compatibility 1.0.0) /usr/lib/libbz2.1.0.dylib
0x936bd000 - 0x93836ffb com.apple.CoreFoundation 6.6.1 (550.19) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x93837000 - 0x93855ff7 com.apple.iChat.IMFoundation 5.0.2 (745) /System/Library/Frameworks/IMCore.framework/Frameworks/IMFoundation.framework/Versions/A/IMFoundation
0x93856000 - 0x9389cffb com.apple.CoreMediaIOServices 130.0 (1035) /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x9389d000 - 0x938edff7 com.apple.framework.familycontrols 2.0.1 (2010) /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x938ee000 - 0x939d2ff7 com.apple.WebKit 6531.22 (6531.22.7) /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x93aea000 - 0x93bebfe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) /usr/lib/libxml2.2.dylib
0x93bec000 - 0x93beeff7 com.apple.securityhi 4.0 (36638) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x93bf4000 - 0x93c63ff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x93c64000 - 0x93c76ff7 com.apple.MultitouchSupport.framework 204.12.1 (204.12.1) /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x93c77000 - 0x93cafff7 com.apple.LDAPFramework 2.0 (120.1) /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x93cb0000 - 0x93d4dfe3 com.apple.LaunchServices 362.1 (362.1) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x93d4e000 - 0x93d6dfe3 libexpat.1.dylib 7.2.0 (compatibility 7.0.0) /usr/lib/libexpat.1.dylib
0x93d6e000 - 0x940d5ff7 com.apple.QuartzCore 1.6.1 (227.18) /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x943ee000 - 0x943f9ff7 com.apple.CrashReporterSupport 10.6.3 (250) /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x943fa000 - 0x94408ff7 com.apple.opengl 1.6.7 (1.6.7) /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x94409000 - 0x94419ff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) /usr/lib/libsasl2.2.dylib
0x9441a000 - 0x94420ff7 com.apple.DisplayServicesFW 2.2.2 (251) /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x94423000 - 0x94426ffb com.apple.help 1.3.1 (41) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x94427000 - 0x945e3ff3 com.apple.ImageIO.framework 3.0.2 (3.0.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x945e4000 - 0x946eaff3 com.apple.DiskImagesFramework 10.6.3 (283) /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x946f8000 - 0x94706fe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) /usr/lib/libz.1.dylib
0x94707000 - 0x947bdfff libFontParser.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x94901000 - 0x94902ff7 com.apple.audio.units.AudioUnit 1.6.3 (1.6.3) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x94903000 - 0x949f7ff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) /usr/lib/libiconv.2.dylib
0x949f8000 - 0x949fbff7 libCoreVMClient.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x949fc000 - 0x94a20ff7 libJPEG.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x94a2c000 - 0x94a33ff7 com.apple.iChat.IMUtils 5.0.2 (745) /System/Library/Frameworks/IMCore.framework/Frameworks/IMUtils.framework/Versions/A/IMUtils
0x94a34000 - 0x94a77ff7 libGLU.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x94a78000 - 0x94a9afef com.apple.DirectoryService.Framework 3.6 (621.3) /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x94aec000 - 0x94aeeff7 libRadiance.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x94aef000 - 0x94afaff7 libCSync.A.dylib 543.33.0 (compatibility 64.0.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x94afb000 - 0x94b93fe7 edu.mit.Kerberos 6.5.9 (6.5.9) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x94b94000 - 0x94ba8ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x94ba9000 - 0x94babff7 com.apple.QuickTimeH264.component 7.6.6 (1729) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x94bac000 - 0x94c3efe3 com.apple.print.framework.PrintCore 6.2 (312.5) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x94c3f000 - 0x95055ff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x95056000 - 0x9509aff3 com.apple.coreui 2 (114) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9509b000 - 0x950ddff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x950de000 - 0x95911fe7 com.apple.WebCore 6531.22 (6531.22.7) /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x95912000 - 0x959edfe7 com.apple.DesktopServices 1.5.5 (1.5.5) /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x95a19000 - 0x95a1dff7 libGIF.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x95a1e000 - 0x95a5dff7 com.apple.ImageCaptureCore 1.0.1 (1.0.1) /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x95a5e000 - 0x95a67ff7 com.apple.DiskArbitration 2.3 (2.3) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x95a68000 - 0x95c06feb com.apple.JavaScriptCore 6531.22 (6531.22.5) /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x95c07000 - 0x95c62ff7 com.apple.framework.IOKit 2.0 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x95c63000 - 0x95c70ff7 com.apple.NetFS 3.2.1 (3.2.1) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x95c71000 - 0x95c71ff7 com.apple.Carbon 150 (152) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x95c72000 - 0x95c76ff7 IOSurface ??? (???) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x95c77000 - 0x95c7eff3 com.apple.print.framework.Print 6.1 (237.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x95c98000 - 0x96017ff3 com.apple.RawCamera.bundle 3.0.2 (527) /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x9602b000 - 0x960d9ff3 com.apple.ink.framework 1.3.3 (107) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x960da000 - 0x960ecff7 com.apple.CoreMediaAuthoring 0.700 (700) /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x962b3000 - 0x962e8ff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) /usr/lib/libcups.2.dylib
0x962e9000 - 0x962eeff7 com.apple.OpenDirectory 10.6 (10.6) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x962ef000 - 0x96330fe7 com.apple.MediaKit 10.2 (482) /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x96331000 - 0x96371fe7 com.apple.IMCore 5.0.2 (745) /System/Library/Frameworks/IMCore.framework/Versions/A/IMCore
0x96372000 - 0x964b4fe3 com.apple.QTKit 7.6.6 (1729) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x96524000 - 0x9665bff7 com.apple.CoreAUC 6.04.00 (6.04.00) /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x9666d000 - 0x968cfff3 com.apple.security 6.1.1 (37594) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x968d0000 - 0x96916ff7 libauto.dylib ??? (???) /usr/lib/libauto.dylib
0x96a34000 - 0x96d58fef com.apple.HIToolbox 1.6.2 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x96d59000 - 0x96d59ff7 com.apple.quartzframework 1.5 (1.5) /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x96d5a000 - 0x96dbeffb com.apple.htmlrendering 72 (1.1.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x96dbf000 - 0x96e20fe7 com.apple.CoreText 3.1.0 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x96e21000 - 0x96e35fe7 libbsm.0.dylib ??? (???) /usr/lib/libbsm.0.dylib
0x96e36000 - 0x96e37ff7 com.apple.MonitorPanelFramework 1.3.0 (1.3.0) /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x96e38000 - 0x96e75ff7 com.apple.SystemConfiguration 1.10.2 (1.10.2) /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x96e76000 - 0x96e76ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x96e77000 - 0x96ebaff7 com.apple.NavigationServices 3.5.4 (182) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x96ebb000 - 0x96eecff7 libGLImage.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x96f20000 - 0x96f47ff7 com.apple.quartzfilters 1.6.0 (1.6.0) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x96f48000 - 0x96f54ff7 libkxld.dylib ??? (???) /usr/lib/system/libkxld.dylib
0x96f55000 - 0x96f96ff7 libRIP.A.dylib 543.33.0 (compatibility 64.0.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x96f97000 - 0x97044fe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) /usr/lib/libobjc.A.dylib
0x97045000 - 0x9704fffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x97050000 - 0x970a8fe7 com.apple.datadetectorscore 2.0 (80.7) /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x970a9000 - 0x970a9ff7 liblangid.dylib ??? (???) /usr/lib/liblangid.dylib
0x970aa000 - 0x9712afeb com.apple.SearchKit 1.3.0 (1.3.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x9712b000 - 0x9791a537 com.apple.CoreGraphics 1.543.33 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x97a25000 - 0x97a2cff7 com.apple.agl 3.0.12 (AGL-3.0.12) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x97a2d000 - 0x97a5dff7 com.apple.MeshKit 1.1 (49.2) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
0x97a5e000 - 0x97c03feb libSystem.B.dylib 125.0.1 (compatibility 1.0.0) /usr/lib/libSystem.B.dylib
0x97c04000 - 0x97c7efef com.apple.audio.CoreAudio 3.2.2 (3.2.2) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x97c7f000 - 0x97d38fe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) /usr/lib/libsqlite3.dylib
0x97d39000 - 0x97d6ffff libtidy.A.dylib ??? (???) /usr/lib/libtidy.A.dylib
0x97d70000 - 0x98069fef com.apple.QuickTime 7.6.6 (1729) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x9806a000 - 0x98196fff com.apple.audio.toolbox.AudioToolbox 1.6.3 (1.6.3) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x98197000 - 0x98198ff7 com.apple.TrustEvaluationAgent 1.1 (1) /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x98199000 - 0x981ccff7 libncurses.5.4.dylib 5.4.0 (compatibility 5.4.0) /usr/lib/libncurses.5.4.dylib
0x981cd000 - 0x9823bff7 com.apple.QuickLookUIFramework 2.2 (327.4) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x9823c000 - 0x98246fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x98247000 - 0x982b8ff7 com.apple.AppleVAFramework 4.8.11 (4.8.11) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x982b9000 - 0x982d7ff7 com.apple.CoreVideo 1.6.1 (45.4) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x982de000 - 0x98713ff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x98714000 - 0x987bcffb com.apple.QD 3.35 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x987bd000 - 0x98addfeb com.apple.CoreServices.CarbonCore 861.6 (861.6) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x98b22000 - 0x98b22ff7 com.apple.ApplicationServices 38 (38) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x98b23000 - 0x98c25fef com.apple.MeshKitIO 1.1 (49.2) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.framework/Versions/A/MeshKitIO
0x98c26000 - 0x98c3eff7 com.apple.CFOpenDirectory 10.6 (10.6) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x98c3f000 - 0x98c3fff7 com.apple.vecLib 3.6 (vecLib 3.6) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x98c40000 - 0x98cc2ffb SecurityFoundation 36840.0.0 (compatibility 1.0.0) /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x98cc3000 - 0x98cf6ff7 com.apple.AE 496.4 (496.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x98cf7000 - 0x98d13fe3 com.apple.openscripting 1.3.1 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x98d14000 - 0x98dbdff7 com.apple.CFNetwork 454.9.4 (454.9.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x98dc5000 - 0x98e1bff7 com.apple.MeshKitRuntime 1.1 (49.2) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
0x98e1c000 - 0x98e5aff7 com.apple.CoreMedia 0.484.5 (484.5) /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x98e5b000 - 0x98e70fff com.apple.ImageCapture 6.0 (6.0) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x98e71000 - 0x98eaafe7 com.apple.bom 10.0 (164) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x9905a000 - 0x99135ff7 com.apple.DiscRecording 5.0.3 (5030.4.2) /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x99136000 - 0x992b6feb com.apple.MediaToolbox 0.484.5 (484.5) /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x992bf000 - 0x9936fff3 com.apple.ColorSync 4.6.3 (4.6.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x993b1000 - 0x99533fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) /usr/lib/libicucore.A.dylib
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
Model: iMac10,1, BootROM IM101.00CC.B00, 2 processors, Intel Core 2 Duo, 3.06 GHz, 4 GB, SMC 1.53f13
Graphics: ATI Radeon HD 4670, ATI Radeon HD 4670, PCIe, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 2.1.9.8
Bluetooth: Version 2.3.1f4, 2 service, 19 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: AirPort, AirPort, en1
Serial ATA Device: Hitachi HDE721010SLA330, 931.51 GB
Serial ATA Device: OPTIARC DVD RW AD-5680H
USB Device: Hub, 0x17a0, 0x0200, 0x24300000
USB Device: StudioDock, 0x17a0, 0x0201, 0x24310000
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8502, 0x24400000
USB Device: TransMemory, 0x0930 (Toshiba Corporation), 0x6544, 0x26200000
USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0x26500000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x04500000
USB Device: AT2020 USB, 0x17a0, 0x0002, 0x04100000
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x06100000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8215, 0x06110000
