External Audio Playback Issue
Tim Kling
on May 19, 2010 at 5:02:16 pm
I've got my FCP system hooked up via firewire to an AJA Io for digital to analog conversion. Ultimately the goal is to print to Beta SP.
We are receiving video signal to the decks/monitors via SDI, however no embedded audio. Audio/Video Settings > Audio Playback is set to "Pro Io" not default or built-in. Any ideas?
Michael Gissing
Re: External Audio Playback Issue
on May 19, 2010 at 11:37:58 pm
Check the settings in the AJA preferences. Audio can be SDI embedded or AES on my Kona3. Either way, check and see that SDI Embed is correctly set.
