Audio Problem
Jon Spells
Audio Problem
on May 19, 2010 at 1:35:02 pm
I started making music video dvd's and the problem I just ran into is that when i add a new music video to the timeline i have to add it to a new track. Example if the last video was on V2 and A3,A4 and i want to mix the audio together then i have to add the new video to V3, A5,A6. I was about half way through the project when this started happening. I was using just V2 and V3 but now im getting up V6.
I must have done something because this is not my first dvd that i made.
Just to clarify to you if i have an audio track on A5/6 and want a new audio file then it has to be added on A7/8 in order to have both audio files playing at the same time. If I add it to A3/4 i will not play until the end of the track thats playing on A5/6.
I hope you guys can help me.
Thankx in advance.
Jon Jon
Michael Gissing
Re: Audio Problem
on May 19, 2010 at 11:43:56 pm
The behavior you describe doesn't sound right if you are doing this in Final Cut Pro.So I am guessing that you are trying to edit in DVDSP.
With so little information I can only advise you to edit in FCP and then make your DVD.
Jon Spells
Re: Audio Problem
on May 20, 2010 at 2:44:41 am
Sorry. I am using final cut pro 7. And like I said I was about 8 songs in when this started happening. If I have to keep and songs to new track the what is the maximum number supported in fcp?
Thanks for the quick reply and sorry for mis-info.
