Exporting HDV Still Images - Aspect Ration Issues
Rene Bogovic
on May 16, 2010 at 11:19:36 pm
I am desperately trying to export still images with the correct aspect ratio 16:9 but no matter what still image format I export them as, I am not able to get it right, the still images always turn out stretched (faces and objects in the frame are vertically elongated).
I am using Final Cut Express 4.0.1
My source footage is HDV 1080i60 1440x1080, and I am using the HDV-Apple Intermediate Codec 1080i60.
These are the steps I am taking:
I make a freeze frame from my footage.
I then export the freeze frame using QuickTime conversion, and export it as a still image.
I have tried all the possible options that are given to me (jpeg, pct, etc.) but none seems to get me a final output with the correct aspect ratio.
So far, what I have been doing to correct for the aspect ratio is to use applications like Gimp, but the process is extremely time consuming and I am losing a lot of resolution quality.
How can I export still images with the correct aspect ratio (16:9) directly from Final Cut?
Please Help Me!
Thank You!
Michael Gissing
Re: Exporting HDV Still Images - Aspect Ration Issues
on May 17, 2010 at 12:57:11 am
Unless the timeline sequence is converted to 1920 x 1080, the stills export will reflect the sequence settings of 1440 x 1080. This is normal anamorphic squeeze, typical of the HDV format.
If you export as a tiff it will be uncompressed so then converting in GIMP or photoshop to 1920 x 1080 jpeg won't affect resolution. I don't know if it is possible to batch convert the aspect correction, but it should be possible to find software that can.
John Ford
on May 17, 2010 at 3:33:40 am
Download DV KITCHEN.
http://www.dvcreators.net/dv-kitchen
Its has a thing called time freezer.
Just export your images as movie and you can take pictures of freeze frames..
I just downloaded it yesterday to try it and its killer.. Same aspect ratio, same size exactly, You can even de interlace frames if needed.. PLUS it comes with a load of other stuff..
It3 the demo , to buy it is 79 USD, but you can use it for 19 days..
I have tried exporting stills from FCP, not worth the head pain, better export then picture it with this//
Hope it helps..
Chris Tompkins
on May 17, 2010 at 11:44:26 am
If you open a anamorphic still in PhotoShop you have to choose view image and select widescreen to display the pixels properly.
Chris Tompkins
Video Atlanta
