Slideshow (stills) in FCP 7: Pro Res 1920x1080 30P?
Brad DeCecco
on May 16, 2010 at 2:17:56 am
I'm kind of stuck here - I need to start editing tonight but I can't reach anyone to verify what they told me. I am creating a slideshow (just audio mp3's and jpeg still images - no video) and I asked what I should work and export in and they said: "Sequence Type: Apple Pro Res 1920x1080 422 HQ 1920x1080 30P"
This is for a show on a digital projector in HD I assume, but when I choose apple pro res easy set up, it's only 24p and they seem to imply I should be in 30p. Any thoughts for the best way to do this? Does it matter what I do for the setup if I just export it as H.264 (which they also said to do?) I don't know how to work with non-video footage so well, any help appreciated!!!
Jerry Hofmann
Re: Slideshow (stills) in FCP 7: Pro Res 1920x1080 30P?
on May 16, 2010 at 2:08:10 pm
I have that setting at 30p here...? Look in the sequence presets. It's there for sure in FCP 7.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Brad DeCecco
on May 16, 2010 at 7:54:03 pm
In 'Sequence Settings" under "General?" and if they want it H.264 output, do I choose that in sequence settings or do I do that just when exporting it? Thanks for your help!
Jerry Hofmann
on May 16, 2010 at 8:03:11 pm
Just select any sequence, and type cmd+zero to open it's settings. From there you can load the preset for the 1080p... compress the final to h.264, but edit in 1080 ProRes.
Jerry
