Multicam angle viewing
Jeffrey Lonigro
on May 14, 2010 at 5:47:49 pm
I have a multicam clip generated from pluraeyes. I have sync set to open. When I hit play only the active track is showing in the viewer. When I stop playback the viewer shows all camera angles. Sometimes it works other times not. Any clues?
Michael Sacci
Re: Multicam angle viewing
on May 14, 2010 at 8:30:44 pm
99% of the time the multicam clip has been rendered in the timeline, make sure you turn off Auto-Render. Fastest way to break this is to turn the track off and on and all should be good.
Shane Ross
on May 15, 2010 at 12:27:46 am
IN the RT menu on the timeline, you must check the option, MULTICLIP PLAYBACK.
Shane
