Quicktime 10 problems
Timothy Reed
on May 11, 2010 at 3:03:26 pm
I have tried to export WMV format from quicktime 10 and there is no export function.
Can I retool back to quicktime 7.6 with PRO and get its functionality back without screwing up my FCP 7 Projects?
Many thanks
Tim Reed
John Pale
Re: Quicktime 10 problems
on May 11, 2010 at 4:16:53 pm
QuickTime X is a work in progress. The Quicktime 7 installer is included on the Snow Leopard disc and FCP users are strongly urged to install it. If you have FCS installed, your QT Pro features ate automatically enabled
Jean-Christophe Boulay
on May 12, 2010 at 2:28:51 pm
QT7 should be in your Applications/Utilities folder. You just have to "pro it" with your license code. And put it in your dock. And trash any shortcut to QuickTime X (which sounds way cooler than "10").
JC Boulay
Technical Director
Audio Z
Montreal, Canada
http://www.audioz.com
Timothy Reed
on May 12, 2010 at 2:35:00 pm
To confirm:
The retool back to QT7 will NOT affect my present QTX projects in FCP7?
Geez, a lot of anachronisms
Many Thanks to all who have helped!
Tim Reed
on May 12, 2010 at 3:10:30 pm
The version of the QT application you open shouldn't have any influence on the QT ressources FCP relies on. Do not delete QTX itself, of course, that would create a mayhem. Just open QT7 instead.
JC Boulay
Technical Director
Audio Z
Montreal, Canada
