Final cut capturing to separate clips?
Thomas Morter-Laing
on May 10, 2010 at 9:14:09 am
Hi there,
I'm trying to capture a clip from a tape in one go into ONE clip, at the moment final cut is automatically splitting it into separate clips. I find this weird as well because in the user preferences the "Abort capture on dropped frames" is unticked, as is "Abort ETT/PTV on dropped frames", AND the "On timecode break" drop down box is selected to 'warn after capture'? Can anyone help?
Many thanks,
Thomas
Shane Ross
Re: Final cut capturing to separate clips?
on May 10, 2010 at 5:30:51 pm
What format are you captureing? HDV? That is prone to this as the GOP stream gets broken whenever you start and stop the camera recording.
Shane
Lee Berger
on May 11, 2010 at 1:41:47 pm
That's right. Even is you deselect the checkbox for new clip on start/stop.
Lee Berger
http://www.leebergermedia.com
