Duration
Alexander Hip
Duration
on May 8, 2010 at 10:46:35 pm
Hello. I have 20 clips in my timeline. I want to change the duration of those 20 clips so they are all the same. However, I don't want to change them one at a time. Is there away to apply the same duration to all the clips at once? How do I do that?
thanks.
Jerry Hofmann
Re: Duration
on May 9, 2010 at 11:15:32 am
No way to do this all at one time...
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Alexander Hip
Re: Duration
on May 11, 2010 at 10:36:44 pm
Thanks Jerry, and judging by your resume I will assume you know what you're talking about. One thing though, I noticed if I drag say 5 clips or so into my timeline, I am able to highlight all 5 then right click, duration, and adjust all 5 clips to be the same duration in one shot. So why not 20?
Jerry Hofmann
Re: Duration
on May 12, 2010 at 1:42:56 pm
I tried this when this thread started, and couldn't do more than one. But MAYBE it's a matter of having enough media in every clip for it to happen..?
i.e., say you lengthen a set of clips, if one doesn't contain enough unused media for the length, none are lenghthened. Try shortening a bunch?
Jerry
