Cropping 'Dallas opening credits' style
Marcus de Groot Mulder
on May 7, 2010 at 8:12:44 pm
I need to create a video in the style of Dallas' opening credits. The part where the cast is introduced. For every cast member there are three images on a row seperated by oblique lines.
http://hub.tv-ark.org.uk/images/soaps/soap_images/american/dallas_1989c.jpg
With the cropping tool it's only possible to get straight lines.
Can someone point me to the tools do I need to use to get the 'Dallas' effect?
Marcus
cowcowcowcowcow
Shane Ross
Re: Cropping 'Dallas opening credits' style
on May 7, 2010 at 9:06:07 pm
Garbage Matte. 4 point will work.
Shane
Marcus Groot Mulder
on May 7, 2010 at 9:29:28 pm
Thanks Shane. That does work.
And then I ran into the next thing.
After a few seconds, the images on the left and right need to freeze.
Usually I create a freeze frame, but here the freeze frame has the size of the orginal footage and not of the cropped size.
Is there a way to freeze the cropped image?
Marcus
Shane Ross
on May 7, 2010 at 9:51:15 pm
MAke the freeze frame, and then apply the same garbage matte to it. Copy and then Paste Addributes:Filters, or drag the filter from the Viewer onto the clip.
Shane
matthew bradshaw
on May 8, 2010 at 6:29:50 am
... Or use a speed change for the freeze frame.
Matt.
Marcus Groot Mulder
on May 10, 2010 at 7:20:20 pm
Thanks for the help guys.
In my case the easiest solution seems the Garbage Matte 4 point + create a freeze frame and change the speed of that frame to zero.
Mark Suszko
on May 7, 2010 at 9:34:26 pm
Yes, What Shane says. Or build a mask in photoshop first, any shapes you need. The use alpha keying and crop controls to wipe stuff in and out or move it from behind using blending modes. I think if you make a mask, changing the other elements may be easier if you have to make a change later.
