abbreviated list under "RT" pop-up menu
Bob Cole
on May 7, 2010 at 7:02:39 pm
I'm experimenting with a new camera which creates MP4 files, and something happened which I've never seen.
The RT pop-up menu (in the sequence window, on the upper left) has been truncated to just four lines.
1. Play Base Layer Only
2. Record to Tape (grayed out)
3. Use Playback Settings
4. Full Quality
Oddly, the first time I imported files from the new camera, the sequence had its usual 18 lines. Otherwise I'd suspect a codec issue - still do actually.
Ideas?
Bob C
Kevin Monahan
Re: abbreviated list under "RT" pop-up menu
on May 7, 2010 at 7:15:26 pm
Your codec is not supported for Unlimited RT.
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author - Motion Graphics and Effects in Final Cut Pro
