Multiclip Issue: One Clip Not Anamorphic
Kevin Monahan
on May 7, 2010 at 6:04:17 pm
Hi Guys,
I have walked into an edit session where I'm supposed to clean up the timeline and do some color correction.
The editor has completed the edit, but one angle in the Multiclip is not displaying as anamorphic. How would I get this one angle to return to anamorphic? Surely there must be a way.
By the way, this is a BLACK SABBATH concert video - all you metalheads.
Jerry Hofmann
Re: Multiclip Issue: One Clip Not Anamorphic
on May 7, 2010 at 6:55:45 pm
Since it's Ozzy...
copy and pasted attributes? Might work, probably not, but ya never know.
collapse the mutlticlip, and match frame/replace after making sure the anamorphic checkbox is on?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
Kevin Monahan
on May 7, 2010 at 7:14:09 pm
The clips are processing now. What I tried is this:
1. Make sure that Anamorphic is checked for all clips in the Browsr
2. Load Multiclip in Viewer
3. Reveal clip in Browser
4. Drag back to corresponding angle
5. Pop up shows: Add angle or replace affilliates
6. Choose replace affiliates
7. Wait.
I'll let you know what happens in around 20 minutes. It's "cooking".
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author - Motion Graphics and Effects in Final Cut Pro
Kevin Monahan
on May 8, 2010 at 4:04:13 am
FCP Crashed and it took SO long to do this function. Jerry, you had the better idea.
1. Collapse multiclips
2. Reset Distort for one of the problematic clips
3. Copy the Clip
4. Paste Attributes to all other clips.
DONE
Kevin Monahan
Report Post
Jerry Hofmann
on May 8, 2010 at 2:56:47 pm
Now the question becomes... can you uncolloapse them? Try it on a copy of the sequence of course.
Jerry
