FCP Won't Capture HDV?
Ryan Zernec
on May 7, 2010 at 11:54:58 am
Hey guys,
I have a project that was shot entirely in HDV, miniDV tape. I have tried and tried and I cannot get FCP to recognize either of the devices I've attempted to capture from. I have tried the camera itself (don't remember which model, it was borrowed, but I will find out), and I've tried a Sony HVU-M15AU. The ONLY way FCP will capture from either device is with the Apple Intermediate Codec, which I've been told reduces quality. I can't seem to capture straight HDV, no matter what I try.
I'm working with a 15" Macbook Pro, in FCP 5. I've tried turning off the downconvert option on the HVU, and the iLink, no help. I've tried every Easy Setup, and every other setting I can see. Nada. Can anyone help?
I've been thinking about getting a FCP 7 upgrade, would this help??
On a whim I tried capturing with Adobe Premiere, and everything went fine. Go figure.
Tony Brittan
Re: FCP Won't Capture HDV?
on May 7, 2010 at 12:31:23 pm
I believe FCP 5 only captures HDV as Apple Intermediate codec. FCP 6 & 7 will do straight HDV, but you don't want HDV anyway. 6 & 7 allow you to capture as Apple Prores and that's what you want. Don't worry about HQ...regular Prores is perfect. Do a search on the workflow. You really need to upgrade. If and when you do, wipe your drive and start from scratch with a full fresh install.
Hope that helps!
Tony Brittan
Apple Certified Pro - FCP
islandshoreproductions.com
Ryan Zernec
on May 7, 2010 at 1:28:56 pm
Thank you, that helps tremendously! I was hoping to avoiding spending money on the upgrade right now, but I suppose its time anyway. I will give it a shot, thank you!
Ted Ryan
on May 7, 2010 at 2:13:59 pm
If you do end up getting FCP 6 or 7 - capture HDV-Apple Pro Res.
However, definitely do NOT CAPTURE Apple Pro Res "HQ" unless you have a capture card.
Pro Res HQ via FireWire crashes your system, gives you corrupt clips, and capturing hell.
Chris Borjis
on May 7, 2010 at 4:02:15 pm
You can capture HDV with final cut pro 5. it was the first version that supported it.
Ryan Zernec
on May 7, 2010 at 6:54:43 pm
I'm on FCP 5, and I can't get it to recognize or capture from either device that I've tried. If there's a trick to it I'd love to know, because I've tried everything I can think of.
Tom Matthies
on May 8, 2010 at 7:36:34 am
Was that version 5 or 5.1 that worked with HDV?
Tom
Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.--Ferris Bueller
