Multiclips & Sound
Anna Heuss
Multiclips & Sound
on May 6, 2010 at 4:39:57 pm
Hi guys,
I'm sure many people have had this problem, but I cant find a good solution on the internet.
I want to create a multiclip from 3 cameras with same timecode - no problem. But then I've got sound tracks that were recorded separately and also need to be added, and it seems to be impossible to merge sound with a multiclip. If I merge only one clip with the sound and then create the multiclip, the videos all go out of sync.
Also adding the sound track as 4th video track doesnt really work...its there but i cant use it.
Would be very grateful for ideas/suggestions...
Anna
Shane Ross
Re: Multiclips & Sound
on May 6, 2010 at 5:10:58 pm
Why not add it to the multiclip when you add everything else? Mark an in point on everything, then make the clip.
Shane
