lo res comp stills to hi res stills
Andrea Stewart
on May 4, 2010 at 5:22:02 pm
Is there an easy way to get the same move that you put on your comp still on the hi res still when you replace it?
If I copy and paste attributes the still blows up huge because its such a larger file.
Andrea Stewart
Producer/Editor/Director - Owner
Germane Creative LLC
Dave LaRonde
Re: lo res comp stills to hi res stills
on May 4, 2010 at 5:33:53 pm
This is why such things are often created in After Effects, which allows the use of low-res proxies, intended for later replacement. To my knowledge, such capabilities are beyond a mere editing application like Final Cut Pro.
Dave LaRonde
Sr. Promotion Producer
Shane Ross
on May 4, 2010 at 5:34:12 pm
Nope...gotta redo. This is what can take me DAYS to do. depending on how many stills I have. And this is why now I will be using ProRes PROXY as the offline codec that we use. Because using DV, then going to HD, means a LOT of time redoing moves on stills.
Shane
Andrea Stewart
on May 4, 2010 at 6:08:48 pm
Well that stinks. I was hoping it would scale the effect.
Perhaps I'll send to Motion and see if it works any better that way. I hate the back and forth between AE and FCP -- its just a pain.
Andrea Stewart
