First Export to SD DVD
craig reynolds
on May 3, 2010 at 10:20:22 pm
Hi All,
Sorry if I am repeating a common question. I have not seen the answer I need, although it is in much discussion.
I am working on my first FCP 7 project. I captured and edited a one hour project in HDV 1080i PAL.
I need to export to a single layer DVD.
I understand that there will be significant quality loss, but all I want to do is achieve the best quality possible. What is the best export method and settings?
I am running Final Cut Studio 3.
Many thanks for you help.
Michael Sacci
Re: First Export to SD DVD
on May 3, 2010 at 11:08:11 pm
If you want to archive a version that you can reuse to edit or master, do NOT go to DVD. You can chop up the video into about 20 minute segments and burn to a data as data files or better get a BluRay burner and back up the movie file to a DATA bluray.
© 2018 All Rights Reserved
