Compressor quits.
Harvey Zinc
Compressor quits.
on Apr 27, 2010 at 10:01:29 pm
I'm trying to batch process about 1200 files. I've tried to load 250... it quit, 150... it quit, the last time it was around 50 and it quit. It always quits as it was trying to load the files.
Is there a max number of files one can load before it quits?
I've trashed preferences and repaired permissions but it made no difference?
Any other suggestions or methods to process these 1200 mov files?
Harvey
Harvey Zinc
Re: Compressor quits.
on Apr 28, 2010 at 4:21:04 am
I've solved my problem so here is what I did. I created a droplet in compressor and was able to drop hundreds of files into the droplet to be converted. It was simple in my case. All source files were of one type. And the output files, the setting and the destination were the same. So the droplet was a simple one (I understand they can be complex).
Hope this helps others with the Compressor quit problem when loading more than 15 or 20 source files.
Harvey
