compressor unknown time remaining
piff aroni
on Apr 24, 2010 at 2:38:05 pm
I have look around but could not find a solution. I tired digital rebellions compressor reapir and got the following message. I do not know what else is left to do, can someone help me I need to get this project finished.
Detected Compressor 3.0.x.
Resetting Qmaster...
Checking file permissions...
/Library/PreferencePanes/Apple Qmaster.prefPane does not exist. You are advised to reinstall Compressor / Qmaster.
Removing temporary spool data...
Checking computer name...
Trashing preferences...
Trying to start Qmaster...
Relaunching menu bar icon...
Processing complete. Errors were found during processing.
John Pale
Re: compressor unknown time remaining
on Apr 24, 2010 at 3:56:44 pm
It's telling you that your installation is missing the Qmaster preference pane (it's probably missing other items too) and that the problems are not repairable----you need to reinstall.
piff aroni
on Apr 24, 2010 at 4:05:39 pm
how should I reinstall? Do I need to completely remove final cut pro, or can I just remove compressor? Just install qmaster?
John Pale
on Apr 24, 2010 at 4:53:04 pm
http://www.digitalrebellion.com/fcs_remover.htm
