Strange Keyboard Phenomena on SnowLeopard
Karim Daire
on Apr 23, 2010 at 4:11:52 pm
I recently upgraded to Snowleopard and FC Studio 3 and ever since I experience irregular problems with my keyboard settings in Final Cut.
I don't see a scheme there.... sometimes when I load Final Cut the Keyboard setup is changed, when I try to correct it Final Cut tells me its english, not german keyboard layout(I am from germany) before I can readjust my key settings. But other programs don't have this problem.
Also if I restart Final Cut... same problem. If I reboot the system I get correct settings again.
I tried trashing prefs etc. but the problem keeps reappearing.
Any hints or similar experiences since Snowleopard upgrades?
Oh yeah.... I am working with a Macbook Pro.
Karim
Scott Sheriff
Re: Strange Keyboard Phenomena on SnowLeopard
on Apr 23, 2010 at 6:11:27 pm
Did you do a clean install of the OS and FCP, or just upgrade?
Do a search on this forum under 'clean install'.
Scott Sheriff
Director
SST Digital Media
http://www.sstdigitalmedia.com
Karim Daire
on Apr 25, 2010 at 5:17:05 am
Hi Scott,
no, both OS and FCStudio are upgrade installs.
Can I install the Updates without having the previous installs before on a Macbook, I know that FCStudio will work but especially wonder about the OS 10.7 Update?
Thanks for your help,
Karim
-Karim-
Scott Sheriff
on Apr 25, 2010 at 9:31:43 am
That is most likely the problem.
I know Apple says you can upgrade, but in the real world it just ain't so.
Treat both the OS, and FCP as a fresh install. As long as you have a valid ser# for FCP your good. The whole thing is on the upgrade discs.
I would suggest you do a search in this forum using 'clean install', and do a bit of reading first. It will save you a lot of headaches.
Good luck with that.
Scott Sheriff
Director
SST Digital Media
