Smooth Cam Issue
Brett Putman
Smooth Cam Issue
on Apr 20, 2010 at 5:57:45 pm
So, I have some fairly jerky footage shot from a helicopter using a 5D.
I a have trued to use the Smooth Cam in FCP and it looks great when it is compressed and uploaded to Vimeo, but when I take a look at it playing back in realtime on my color accurate monitor, the footage seems jerky, almost as if it is dropping frames.
Am I missing something altogether with the Smooth Cam?
Michael Sacci
Re: Smooth Cam Issue
on Apr 20, 2010 at 6:04:48 pm
have you rendered the clips in the timeline, when applied you normally have green "preview" quality video out until it is rendered.
Brett Putman
on Apr 20, 2010 at 6:20:34 pm
Yes, I have.
Michael Sacci
on Apr 20, 2010 at 6:26:58 pm
I have not seen dropping of frames but the down side of SC is a funky blur and snapping to a reframing, if that is what you are talking about try playing with the settings to get a balance.
Brett Putman
on Apr 20, 2010 at 6:32:10 pm
ok, i will just give that a shot i guess.
do you have any suggestions for any other solutions, in case i seem to get my footage just right?
maybe a piece of third party software?
Jeremy Garchow
on Apr 20, 2010 at 6:33:24 pm
Bring the clip in to Motion. It has more options.
There's also CoreMelt's Lock and Load:
http://www.coremelt.com/products/lock-and-load/lock-and-load.html
Erik Lindahl
on Apr 20, 2010 at 7:53:44 pm
Different stabilizers work differently well depending on shots. I've had great success with FCP's stabilizer and never seen it "drop frames" when rendered. What can be common is the motion-blur on the stable footage (if it's very jerky). The only real way to combat that is lower the stabilization a bit and on a per-frame basis sharpen clips up.
CoreMelt's Lock and Load is also an awesome tool I've more and more started to use as it's got more features and only renders i/o points rather than the entire media (huge plus often).
Erik Lindahl
Freecloud Post Production Services
http://www.freecloud.se
Dave LaRonde
on Apr 20, 2010 at 9:11:27 pm
Did you shoot at 30fps instead of 29.97? Fo a while, those goofball 5D Mk II's could only shoot at 30, and you had to conform the frame rate.
Dave LaRonde
Sr. Promotion Producer
Brett Putman
on Apr 20, 2010 at 10:06:19 pm
it was shot in 23.98 and the sequence setting match that
Tom Adams
on Nov 12, 2010 at 3:37:16 pm
does anyone have any tips on what smooth cam settings work best. i find the setting hard to figure out. ...not getting the results I'm looking for... I've tried to do it with "motions" settings too...but not familiar with etc..
help?
Regards,
Tom Adams - Director/Owner
Reelife Documentary Productions
"cool digital video stuff...not boring or dumb"
http://www.reelifeproductions.com
Williamsburg, MA, USA
http://www.FolktographybyTom.com
Folktography.zenfolio.com
MacPro
FCP studio2
4TB Firewire Drives
Panasonic DVX100a & EZ1
