Animation codec
John Weisenburger
Animation codec
on Apr 19, 2010 at 5:02:25 pm
Hi all. I am having issues with my workflow and am hoping someone can steer me in the right direction.
I am editing in FCP 6 and using AE CS4 for keying with Keylight. My sequences in FCP are in Pro Res 422. I had been exporting from AE in the animation codec as I was under the impression I would lose the least quality...however, as I expected, FCP can't handle that codec and and constantly freezes, etc...
Can I export from AE in Pro Res 422? Am I going to lose much quality, or any at all? This footage was shot with the Sony EX3 and will ultimately be output from FCP in a self contained Quicktime so as to be transferred to HD Cam.
Any help as to best workflow/pointing out mistakes would be greatly appreciated.
Jeremy Garchow
Re: Animation codec
on Apr 19, 2010 at 5:21:25 pm
Do you need the alpha channel? Then if so, you must remian with animation, or upgrade to FCP7 which has a real time alpha channel in ProRes 4x4.
If you don't need the alpha, you can render ProRes out of AE.
Dave LaRonde
Re: Animation codec
on Apr 19, 2010 at 6:29:13 pm
[Jeremy Garchow] "...If you don't need the alpha, you can render ProRes out of AE. " long as the the AE machine ALSO has FCP installed on it. That's the only way, I believe, to have access to the codec for file writing purposes.
But frankly, I don't know why the guy can't just highlight the clip, render it in the timeline, and be done with it. Okay, you make changes and it's another re-render, but it's not THAT big a deal.
Dave LaRonde
Sr. Promotion Producer
© 2018 All Rights Reserved
