FCP 7/Quicktime X Aspect Ratio Issues.
Lucas Way
on Apr 18, 2010 at 3:02:07 pm
Hi all.
So basically, after upgrading to Snow Leopard (and in turn Quicktime X) I'm havign some very wierd aspect ratio issues in FCP.
So I have to make a showreel of previous projects of mine & after importing them into FCP 7 things aren't going right.
The films were all exported as PAL 16:9 QT files from FCP6, and when I open them in QT7 they look their normal 16:9 self... however upon opening them in Quicktime X they are stretched horizontally so that they are super widescreen, distorting the image in the process.
This wouldn't normally bother me as I can easily watch them on QT7
BUT
When importing those files into FCP7 they're having the same issue, showing up on the preview screens as this stretched super-widescreen image, which of course, I do not want.
I've looked in the video properties on QT7 (a feature stupidly missing from X) & adjusted them to be 16:9 dimensions, even after doing that, they still show up as super widescreen in QTX and FCP7.
[Does FCP7 use QTX as it's underlying video format like FCP6 used QT7?]
Please can anyone help me out on this? This showreel is due very soon as at the moment I can't even start since the files are such a weird aspect ratio.
John Fishback
Re: FCP 7/Quicktime X Aspect Ratio Issues.
on Apr 18, 2010 at 4:12:53 pm
In FCP in the Motion tab check if the distort settings are causing the problem. If so, you can use Remove or Paste Attributes to fix.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
