Clips have diferent in/out on export...
Ben Bigelow
on Apr 17, 2010 at 4:54:42 am
The problems never end...
When exporting my sequence I have this problem where clips from the same footage item, no matter where they are in the sequence, have different in/outs. Meaning the length of the clip and when the cut happens in the sequence stays the same, but the footage itself is from a different moments in time than is visible when viewing withing FCP.
This only happens with clips pulled from one of my footage items. All of the other clips from different source footage is fine. However, to my knowledge (what I can tell from the "format" info), all of my footage is in the same format.
I've tried exporting to a variety of codecs with both compressor and using quicktime conversion...still happens.
Anyone experience this before/know any solutions?
My footage:
 myspace image hosting
My sequence settings:
(ugh hard to see, the image uploader isnt working so i used an external one, but its just the Anamorphic PAL preset)
THANKS FOR THE HELP
Rafael Amador
Re: Clips have diferent in/out on export...
on Apr 17, 2010 at 4:57:34 am
Hi Ben,
In the Renders Folder, delete the "Constant Frame" folder and try again.
rafael
http://www.nagavideo.com
Ben Bigelow
on Apr 17, 2010 at 5:07:53 am
Rafael to the rescue again!
However same problem, deleting the constant frames folder didn't work. I've also trashed my preferences. :(
