Broadcast output settings
gabriele gismondi
on Apr 16, 2010 at 8:57:06 am
thanx to Your help i finnaly came out of my timeline with a Prores Qt movie that i like.
I'd be giving this to regional TVs and i'm not sure about specs to keep in terms of colour/contrast since i've made my levels for the web.
Is there a way to keep levels in the TVs range and what about Broadcast effect in the effects tab..i don't get the use of it..and i do not have an ext monitor..
thanx for help
Chris Poisson
Re: Broadcast output settings
on Apr 16, 2010 at 2:20:42 pm
Use your scopes to check your levels. Different stations will have different requirements, you need to check with each.
gabriele gismondi
on Apr 16, 2010 at 2:30:01 pm
ok, thanks, i'll be checking for "green circle" on clips to make sure..i'm on the right way..
tnx again
Chris Poisson
on Apr 16, 2010 at 2:35:16 pm
Yes, but don't forget your scopes, I use the waveform monitor to check black and white levels. Also, you might try the broadcast safe filter and see what that does to your levels.
Michael Gissing
on Apr 16, 2010 at 10:28:14 pm
Broadcast safe is not reliable after render. Search this forum as there are a few better ways to make you clips broadcast safe for both levels and Chroma.
