Exporting more than 2 audio tracks?
tom douce
on Apr 15, 2010 at 11:58:06 am
Hi all,
I am trying to export a sequence with 6 audio tracks using Menu->File->Export->Using Quicktime conversion... and it seems to be impossible to export to more than 2 audio tracks !
If I use the option Export->Quicktime movie I can export my 6 audio tracks but I don't want to export to .mov file...
Can anyone confirm or has a solution ?
Note : Using File->Export->Using quicktime conversion option, even if I select Quicktime movie or aiff file or ogg as destination format I cannot export more than 2 audio tracks.
Thanks in advance.
Tom
Michael Gissing
Re: Exporting more than 2 audio tracks?
on Apr 15, 2010 at 11:28:21 pm
What are you exporting to, if not a .mov? You may have to export the audio separate to the picture but without any info as to what you are trying to end up with I can't guess.
Have you tried Compressor?
tom douce
on Apr 16, 2010 at 7:12:11 am
Hi !
I tried to export to Quicktime movie, ogg or aiff but no one let me export more than 2 audio tracks by using Menu->File->Export->Using quicktime Conversion... option.
I need to use this option because I made my own Quicktime export plugin and I want to be able to export more than 2 audio tracks
