Why 3 frames out of Sync on capture
Glyn Bowerman
on Apr 13, 2010 at 9:48:33 pm
I have been using a Mac pro with an AJA Io for the past 5 years with no problems.
We have just upgraded to a new MacPro with an AJA Io HD & FCP 7
When I capture through the AJA to ProRes it is 3 frames out of sync, very slight but noticable.
I turned of the AJA and did a straight Firewire capture and this was also 3 frames out of sync
Any ideas why?
David Roth Weiss
Re: Why 3 frames out of Sync on capture
on Apr 13, 2010 at 10:18:58 pm
See this answer from yesterday:
http://forums.creativecow.net/readpost/8/1082619
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
EPK Colorist - UP IN THE AIR - nominated for six academy awards
A forum host of Creative COW's Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Michael Gissing
on Apr 13, 2010 at 11:18:20 pm
3 Frames is gross not slight. Audio pros agonize over sub frames. It drives me nuts that my LCD has a half frame latency and I can only compensate playback delay in frames.
David Roth Weiss
on Apr 13, 2010 at 11:32:15 pm
[Michael Gissing] "udio pros agonize over sub frames."
Michael,
My editing mentor of nearly thirty years has always said to me that, "an edit that's one frame off is a bad edit."
I'm gonna have to call him now and tell him that he got it all wrong, that he should have said, "an edit that's one sample off is a bad edit."
David Roth Weiss
Los Angeles
Michael Gissing
on Apr 13, 2010 at 11:40:05 pm
[David Roth Weiss] ""an edit that's one sample off is a bad edit.""
That's a bit harsh. There are 2000 samples per PAL frame so I would say +- 500 samples for sync. For a dialog edit, yes we go right down to the sample level to fix clicks or take to edge off a plosive.
Glyn Bowerman
on Apr 14, 2010 at 11:40:56 am
Hi David
I've checked my old system and it was set to 4 and sync issues were never a problem. Why would it be the case now?
By having it offset to 4 what does this achieve? Does it offset it on the timeline as it plays out?
