HDV-M25U and FCP
Terry Ballard
HDV-M25U and FCP
on Apr 13, 2010 at 9:23:40 pm
Can anyone help... I'm using FCP and SONY's HDV-M25u HDV deck. The deck is connect via firewire I have a plasma that I want to see my finished project on. I want to play my timeline, pass through the deck via HDMI and see in on the plasma. What are the deck settings/project setting?
Any and all info is appreciated.
Terry B
Arnie Schlissel
Re: HDV-M25U and FCP
on Apr 14, 2010 at 1:48:25 am
[Terry Ballard] "What are the deck settings/project setting?"
There are none. The only way to play HDV out is with a capture card.
Post production is not an afterthought!
Andy Mees
on Apr 14, 2010 at 6:23:47 am
Set you Video Playback to "Apple Firewire" (PAL or NTSC as appropriate) and this will send your HDV timeline to your M25 deck as a letterboxed SD DV signal (via a realtime software downconvert courtesy of FCP's RT Extreme playback engine) ... you should be able to watch that on your plasma via the deck, but it'll be pretty crap I'm afraid.
© 2018 All Rights Reserved
