NTSC problems
Charlie Key
NTSC problems
on Apr 12, 2010 at 3:56:39 pm
Hey Guys,
I have problem with a dvd from the states (I am in Uk). When I play with Dvd player app, it plays fine but when I open in Mpeg streamclip rip it plays terribly which I guess is the difference in frame rate. I believe it is from a NTSC pal file (in Streamclip it says native resolution is 720 x 480), I need to get it playing in an Xdcam ex timline on FCP.
Any thoughts? Thanks in advance,
Charlie.
Rafael Amador
Re: NTSC problems
on Apr 12, 2010 at 4:25:22 pm
[Charlie Key] "it plays fine but when I open in Mpeg streamclip rip it plays terribly which I guess is the difference in frame rate. "
If you rip a DVD you should be getting an standard file. Pal or NTSC, should play fine in MPGStreamclip.
I'm a Pal lander too, so what I guess is that your MPEG-2 is p24 with pulldown.
Little experience (thanks God) about this, but I suppose that you need to remove that pulldown.
If I'm wrong any of our numerous NTSC pals will tell us.
rafael
http://www.nagavideo.com
Pleas have a look to my clip:
http://reels.creativecow.net/film/4452
Feedback welcomed
Charlie Key
Re: NTSC problems
on Apr 12, 2010 at 4:40:40 pm
"If you rip a DVD you should be getting an standard file. Pal or NTSC, should play fine in MPGStreamclip. "
Thats what confused me, it plays OK in DVD Player app, but not in MPEG Streamclip. Otherwise, I would just chuck it in the bin!
Do you think i should just rip at 29.97 fps to NTSC Pal?
Rafael Amador
Re: NTSC problems
on Apr 12, 2010 at 5:36:04 pm
[Charlie Key] "hats what confused me, it plays OK in DVD Player app, but not in MPEG Streamclip. Otherwise, I would just chuck it in the bin! "
I don't know what to tell you.
May be MPGStreamclip is more exigent. You know that many times things look well in QT, and in FC doesn't look the same.
I prefer to wait some expert to guide you. If I miss lead you, somebody will screem to me.
BTW, had you had a look to the "Info stream" in MPGStreamclip?
rafael
Feedback welcomed
