Can't import one .mov file?
John Pastuch
on Apr 7, 2010 at 6:07:52 pm
I shot a scene on my DVX100 straight to my friends Macbook Pro through FCP 7. We checked and imported all the footage afterwards, and everything seemed OK.
I'm editing on a desktop Mac at school which has FCP 6.6. I had all the .mov files we captured on my harddrive, and every single one of them imported correctly- except one. The file is the same framerate, bit rate, file extension- everything about it is the same and it plays correctly in quicktime- but it simply will not import into FCP. I get the error message that the file format isn't recognized.
Is this a common problem?
Dave LaRonde
Re: Can't import one .mov file?
on Apr 7, 2010 at 6:18:41 pm
If Quicktime can read it, just export in QT using the original settings of the clip. If QT can't read it, there are other issues going on and you should re-capture.
Dave LaRonde
Sr. Promotion Producer
John Pastuch
on Apr 16, 2010 at 10:10:56 pm
I know it's been a while since this post, but I'm coming back to the mov file and while it plays fine in Quicktime, it still won't import- how exactly do I export within Quicktime with the same exact quality- everytime I do it, my file size is 100 mb less...
thanks
Dave LaRonde
on Apr 19, 2010 at 6:23:10 pm
[John Pastuch] "how exactly do I export within Quicktime with the same exact quality- everytime I do it, my file size is 100 mb less..."
It sounds like QT isn't exporting the entire file, which leads me to believe the file is corrupted. I'd recapture the shot.
Dave LaRonde
