HDV as Pro Res in ProRes LT TImeline to SD DVD?
Kevin Monahan
on Apr 6, 2010 at 7:06:42 pm
Yet another HD to DVD question!
I have a ProRes LT timeline. All the HDV footage was captured as ProRes. Client wants a SD DVD. Should I make an intermediate ProRes SD file or go straight to MPEG 2 via Compressor?
Thanks guys.
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author - Motion Graphics and Effects in Final Cut Pro
Jerry Hofmann
Re: HDV as Pro Res in ProRes LT TImeline to SD DVD?
on Apr 6, 2010 at 7:09:08 pm
I see no reason at all to export a downconverted file first... just go right at compressor and do the deed from the ProRes LT sequence I'd suggest.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX Cinema Displays
John Fishback
on Apr 6, 2010 at 9:42:13 pm
I do this all the time with DVCProHD footage. I export a QT using Current settings and use that HD file in Compressor to make the SD mv2 & ac3 files.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
