ProRes SD resolution
Chris Anderson
on Apr 6, 2010 at 6:00:50 am
I am editing a project which contains DV video and After FX animations. In the past, I would create a DV50 sequence to help with the graphic quality.
However, this time I chose a ProRes 422 SD sequence but I changed the sequence settings to a 720x480 instead of 720x486 to match all my media.
I do get the occasional "not optimal setting" warning but everything seems to play fine. Should I expect any problems with this work flow?
It didn't seem correct to keep it at 486 since everything in the sequence is 480.
The final output will be a DVD.
Chris
Chris Anderson
Rafael Amador
Re: ProRes SD resolution
on Apr 6, 2010 at 6:26:39 am
Hi Chris,
Don't worry about.
Prores 720x480 works without problem.
rafael
http://www.nagavideo.com
