Need help recording VO with MicPort Pro
Colleen Stratton
on Apr 3, 2010 at 4:16:45 pm
I am running FCP 5.0 on a G5, 10.4.11. I'm trying to record with the VO tool in FCP using a MicPort Pro and Sennheiser ME 64 mic. It records in Garage band nicely, but in FCP I'm getting a weird hum and the recorded voice sounds like a cartoon character. Clearly, it's not set up properly. Can someone walk me though the correct FCP settings?
Chris Tompkins
Re: Need help recording VO with MicPort Pro
on Apr 3, 2010 at 5:36:31 pm
If you're going live into FCP, I would run it thru a mixer and look @ your levels. Choose capture now and set the deck control to none (non-controllable)and look @ your levels in FCP as well.
Chris Tompkins
Video Atlanta
Colleen Stratton
on Apr 4, 2010 at 4:13:49 pm
Hi Chris,
Thanks for your response. Unfortunately, your suggestion would require another major purchase, which I'd rather not have to do. The MicPort pro is a clever little preamp that plugs directly into the computer via USB. Log and capture only works with firewire. I've been told MicPort pro works with FCP. I think all I need to do is change a setting in FCP to get it to work. If anyone has experience with this device and can tell me how to set it up, I'd appreciate it.
Thank again,
Colleen
