Mixing 720p in 1080i sequence
Peter Hall
on Apr 2, 2010 at 8:24:11 am
I am adding 720p mts footage into a HDV 1080i sequence by importing through L&T (fcp 7) and it seems to play ok alongside the HDV footage. Do I need to change the 1280 x 720p files into 1080 x 1440?
Peter Hall
Robb Harriss
Re: Mixing 720p in 1080i sequence
on Apr 2, 2010 at 12:30:13 pm
you'll have a lot fewer issues if you make everything the same, less rendering and fewer calls for help later when things aren't quite "right."
Non-linear: all the time and nothing but.
John Fishback
on Apr 2, 2010 at 1:59:55 pm
I agree with Robb. You can use Compressor to convert and make sure you enable Frame Controls. Choose the Best quality settings for re-sizing and if the frame rate has to be converted choose Best for that, too. While I've never used it, ClipWrap might also help.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
Robb Harriss
on Apr 3, 2010 at 4:07:09 pm
John,
Just glanced at ClipWrap, looks interesting. Fortunately I don't have to deal with rogue codecs very much at all.
